Go to Post But don't forget about the little details, that can (and will) come back to haunt you. - Ben Piecuch [more]
Unread 08-01-2017, 17:28
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Auto Rotor Point Total?
Originally Posted by ollien View Post
Interestingly, unless I'm missing something, the manual doesn't reflect this "three full rotations" bit. Only the field tour.
According to the field tour, the FMS doesn't recognize that the GEAR set is being rotated until after three rotations, so that indicates to me that the scoring will coincide with the rotor actually turning, or in case of a field issue, the corresponding light activating.
I do wish that the manual didn't say the GEAR sets "engage the corresponding rotor." That implies to me that the GEAR sets are physically meshed with the rotor, when the field tour explains that the GEARs drive an encoder, which tells the FMS to turn on the rotor.
"It's taking longer than expected, which was to be expected."
Unread 08-01-2017, 18:06
Zeke E's Avatar
Zeke E Zeke E is offline
Shop Slave/Mechanical Master
FRC #4329 (Lutheran Roboteers)
Team Role: Mechanical
Rookie Year: 2016
Zeke E is an unknown quantity at this point
Looks like we've got ourselves a steamacrit. It is odd that we don't have any written proof of how many rotations it takes, if there is a set number. Field tour makes sense, but I just can't bring myself to trust something not in the manual.
Unread 08-01-2017, 20:43
Josh Tatum Josh Tatum is online now
FRC #0303 (T.E.S.T team)
Team Role: Electrical
Rookie Year: 2014
Josh Tatum is an unknown quantity at this point
Re: Scoring of rotors
If they do not change the rules, a team could take the reserve gear and put it into the first Rotor. This would get them the 100 points but because the other alliance to also get 25 points which means that the alliance would net 75 points, which is greater than the 40 they would get if they waited for teleop.
Unread 08-01-2017, 21:16
Bronze Bronze is offline
FRC #0701 (RoboVikes)
Rookie Year: 2012
Bronze is an unknown quantity at this point
Good point. However, if you did do this, by employing a strategy that purposefully generates a foul (repeatedly), you are going quite seriously against the spirit of FIRST.
That being said, I am almost certain that the rules intended for autonomous rotors to be 60 points total, not 60 then 40. This would make the tech foul for taking the reserve gear and powering a rotor more of a penalty than the point bonus for getting an auto rotor. (you get 20, they get 25).
Unread 07-01-2017, 18:53
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Good question. I'm sure the answer is going to be, "However FMS is programmed to score it." And I'd guess it would be scored either 60 or 40, not both.
But if a ROTOR is turning at time T=0 of Auto, then it's also turning at time T=0 of Teleop. So technically it should count both, per Table 4.1. Unless FMS turns off any turning ROTOR at the end of Auto.
Q&A will be the only definitive answer.
Edit: I'm pretty sure it would have to be one or the other, not both. Else the FUEL scored in Auto would also count again in Teleop.
(since 2004)
Unread 09-01-2017, 02:10
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Originally Posted by botster View Post
I would just like to point out that there has been no rule against all three robots placing their gear on the close spring. That would make scoring three gears considerably easier and faster than having robots drive to the far side of the airship, turn, and then place their gear.
Interesting idea, although I'd definitely check the Q&A for legality.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
