Go to Post "Congratulations to our FIRST team coming back from the championships in St. Louis." (We all applaud) "Remember, if you're not FIRST, you're last!" - Our pilot on the second plane back home. - demosthenes2k8 [more]
Unread 07-01-2017, 17:44
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Question Lift Peg (Spring) Source?
The McMaster listing https://www.mcmaster.com/#9664k68/=15ta0ri as per the field drawing is showing "usually ships in 2 weeks" and our order confirmation says "ships in 2-4 weeks
Anyone have leads on other (more readily available) sources?
2002 -> 2006: Student, 417 (Stangbots)
2008 -> 2010: Mentor, 125 (NUTRONS)
2014 -> NOW: Mentor, 2039 (Rockford Robotics)
Unread 07-01-2017, 23:37
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Re: Lift Peg (Spring) Source?
In the same boat, been searching but can't find an alternate source. Would appreciate any help!
Unread 08-01-2017, 00:02
garpal_robotics's Avatar
garpal_robotics garpal_robotics is offline
AKA: Mark Sawyer
FRC #5920 (VIKotics)
Rookie Year: 2012
garpal_robotics is an unknown quantity at this point
Hi folks-- ran into the same issue. I ordered the 9664K68 and will wait the 2 weeks for the real deal... However right above that spring on McMaster is: 9664K31 it is a lighter gauge wire .105 vs the .135 but it has the same outside diameter... I think it will get us through prototyping in week one. (it was available right away)
Hope that helps a little.
Unread 08-01-2017, 00:23
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Word of warning: 9664K31 won't behave anything like the official spec 9664K68. The field official spring has 24lb starting force and 159lb/in spring rate. The replacement you spec'd is a 9lb spring with only 14lb/in spring rate, nearly an order of magnitude less stiff than the competition spec.
Unread 08-01-2017, 01:03
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Try this. They also have Canadian distribution so will ship without brokerage. http://www.essentracomponents.com/en...springs/es-241
Unread 08-01-2017, 03:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Just call McMaster. "ships in 2 weeks" tends to be the standard placeholder for "we don't have this at the moment". I've almost always had that 2 weeks go down to 1-2 days when I call and say I need it sooner.
I'm sure it's gonna be longer than 2 days in this case but I would be surprised if McMaster is actually out of stock for 2 weeks. It may just be an automated status since they got a massive run on an item they probably sell 1 or 2 of a day at most.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2017, 03:59
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Rookie Year: 2012
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
Don't forget McMaster has five regional distribution centers. You might be able to pick one up if you're located near one of the warehouses.
Unfortunately I wasn't able to determine the location of all of the regional warehouses, but I do know we have one here in Kansas City.
Can't hurt to call and ask for directions to a warehouse, or rushed fulfillment.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 08-01-2017, 07:33
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
The five regional distribution centers are in Atlanta, Chicago, Cleveland, Los Angeles, and Princeton (NJ).
Also have any Israeli teams found an Israeli distributor with an equivalent spring?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2017, 08:20
AKA: Josh Patterson
Rookie Year: 2012
Hmmm, we definitely got McMaster parts locally (Kansas City) when I was on a team, any idea of a warehouse closed in the past couple years?
2016-Present FTAA
Unread 08-01-2017, 08:24
Ari423's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
No idea but those are the 5 listed on their website (top left corner)
2013: Programmer
Unread 09-01-2017, 05:19
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Nope, and mcmaster doesnt ship to Israel even if it was in stock.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 11-01-2017, 14:55
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
To add to this; as one of the teams close to the NJ distribution center, one of our mentors stopped in for an order pickup today. They know us, as well as a lot of the local teams - and are excited about Steamworks!
To the point... the lovely man behind the desk let us know that other teams had come in looking for the spring, and not only did they not have it in our distribution center, but that it is currently out of stock in all fifty warehouses that he can see the stock lists for.
So it sounds like this thread of duplicates/acceptable substitutes will be super valuable! As we get ours in (we got the Amazon one) we'll take photos/video of interactions as best we can.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 08-01-2017, 15:18
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Greetings,
I am looking at the "team build" wood drawings. I do not see a cut length for the 7/8 diameter spring. McMaster shows the part is 36" long. I doubt we need all that. Home Depot sells a 7/8 with some ends that i would have to cut off.
Anyone see the spring length for the team build?
Thanks, Troy 2450
Unread 08-01-2017, 15:47
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
Rookie Year: 2010
one4robots is on a distinguished road
Originally Posted by TroyCDH View Post
Greetings,
Thanks, Troy 2450
Hi Troy,
The length is 9" per the team build plans. We bought a spring at Menards that is that length, but not as thick guage, therefore not as stiff. It works fine for prototyping.
Vince
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
  #15   Spotlight this post!
Unread 08-01-2017, 16:22
Ubiquity Ubiquity is offline
FRC #5027
Ubiquity is an unknown quantity at this point
I found a 12 inch extension spring at Home Depot, sku 172 045 15637. Cost about $7. This is the Everbuilt (Home Depot branded) spring found near door hardware.
Looks like it will work just fine, It may be a little less stiff than the McMaster.
Available today! (I do not work or endorse Home Depot Products. )
https://drive.google.com/open?id=0B2...mNwMGxsZ3ZOVU0
Former mentor: 255(4y), 254(2y), 668(1y), 751(1y),5027
Current mentor 2854, 5905
Volunteer, Ref, Inspector, Judge, FTA
Nat. Champion 2000(255), Nat. Chairman's 2004(254), SVR Champion 2015(5027)
(Botball N. Champ 2001)
Last edited by Ubiquity : 09-01-2017 at 13:03. Reason: Include picture finished field element
