Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Unread 07-01-2017, 19:06
Ichlieberoboter's Avatar
Ichlieberoboter Ichlieberoboter is offline
Awards and Programming
AKA: Maria Valentini
FRC #2499 (Industrial Revolution)
Rookie Year: 2012
Ichlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud of
Gear hole diameter?
Looking through the manual, we saw the gear dimensions but we couldn't seem to find anything that had the dimensions of the hole in the gear? Obviously the easiest solution would be to just measure it, but our coach has our kop until Monday and we are trying to work on design ideas today! We may have just missed it, sorry if we did, but thank you for any help!
Team 2499-Industrial Revolution
2015 Lake Superior Regional Judges Award
Head Programmer Chairman's Award Presenter Awards Submitter Electrical Team Website Designer Strategy Team
Unread 07-01-2017, 19:16
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: Gear hole diameter?
the peg on the airship where the pilot installs the gear has a diameter of 7/8". the gear is a very loose fit, so i would estimate between 15/16" and 1" diameter.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 07-01-2017, 19:18
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Team Role: Leadership
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
1"
Source: http://files.andymark.com/LayoutPrin...0T+gear+v1.PDF
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 07-01-2017, 20:16
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
Rookie Year: 2013
MasterEric is an unknown quantity at this point
Keep in mind, the peg is 1-3/8 inches wide. In order to put the gear on the peg you must put it in one of the large side holes between the "spokes".
Unread 07-01-2017, 21:07
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
the peg I meant in this case is on the railing as part of a GEAR TRAIN. The LIFT also has a peg, which is as you described.
