Ranking Points in Steamworks unclear
On page 14 of the game manual, there are the guidelines for how to earn ranking points.
It states, "Alliances are seeded in the Qualification tournament using ranking points which are awarded based on a combination of their Win-Loss-Tie record (2 points for a win, 1 point for a tie), the number of times they reach a 40 kiloPascal (kPa) pressure threshold (1 point), and the number of times they start all rotors (1 point)." I am very confused about the points for KiloPsacals. Does this state that every time you get 40 Kilopascals you get a ranking point or do you just get it the first time you get 40? Thanks for the help in advance and good luck from team 5980! |
Re: Ranking Points in Steamworks unclear
It's a threshold, it's a value that you must surpass.
tldr; You just get a ranking point the first time you hit 40. |
Table 4-1 says a team can only get one ranking point per match for pressure accumulation.
The only thing I'm not clear on (and this is only a corner case): Table 4-1 says "If ALLIANCE exceeds a threshold pressure of 40 kPa". Section 10.4.3-D says "Each Team on an ALLIANCE that achieves at least 40 kPa receives one (1) Ranking Point." (bolding is my emphasis) So, if the alliance gets exactly 40 kPa, do they get ranking points or not? |
I too would agree. The game manual seems to contradict it self.
Section three reads as follows Quote:
However, Table 4-1 says Quote:
I've been corrected Last edited by KosmicKhaos : 07-01-2017 at 21:20. |
there are may ways to score 40kPa exactly. exactly 120 high goals in teleop is one way.
To make it simple (per match):
A win is 2 RP (same as last year) A tie 1 RP (same as last year) ----------------- 40 kPa is 1 RP (similar to a Breach last year) 4 Rotors turning is 1RP (similar to Capture last year) Last edited by Boltman : 07-01-2017 at 21:19. |
A clearer way to state this is "the number of matches in which the alliance reached a 40 kiloPascal (kPa) pressure threshold (1 point)"
#10
I would say it is at least 40kPa, based on the fact that the rule states "at least" while a summary table paraphrases and uses another word. I would consider the summary table to be a helpful reference to the rule, with the rule holding the actual authority on the matter.
#11
We were working on the assumption that the RP's from shooting are technically unlimited as stated on page 14, although they would be limited by the 4 balls/second processing speed of the boiler. Why else would the 40 kPa only be worth 20 points in the playoffs when getting all the rotors turning is worth 100 points in the playoffs? That seems pretty unbalanced unless you get the 20 points for every 40 kPa, in which case it makes perfect sense.
We'll submit a question to the Q&A when it opens, but hopefully FIRST will clarify before then because it's a pretty important strategy decision. |
#12
