Go to Post I watch students push themselves beyond their limits every year only to realize they have yet to find their true limits. - JesseK [more]
Unread 08-01-2017, 00:03
Darksainor Darksainor is offline
FRC #4635
Darksainor is an unknown quantity at this point
Error while trying to setup NetworkTables on PC
Hello, my team and I are currently trying to implement vision processing on our robot, in order to do so we will have a PC perform all the work and send the data to the roboRio through a NetworkTable, the problem is that i cant seem to build the .cpp file for setting up the PC side of the program. Here are both the program and the output when I attempt to build it.
Program (This is just for testing and learning purposes):
#include <ntcore.h>
#include <networktables/NetworkTable.h>
using std::shared_ptr;
int main() {
NetworkTable::SetClientMode();
NetworkTable::SetIPAddress("10.46.35.2");
NetworkTable::Initialize();
shared_ptr<NetworkTable> myTable = NetworkTable::GetTable("SmartDashboard");
myTable->PutString("ExampleString", "Sample Text");
NetworkTable::Shutdown();
return 0;
Output:
https://drive.google.com/file/d/0By8...NIYnVTeEU/view
I see that the problem is related to something caller llvm, but I cant seem to find a way to fix this, please help :c
Unread 08-01-2017, 00:26
fsilberberg fsilberberg is online now
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Error while trying to setup NetworkTables on PC
You'll want to link against libwpiutil.so as well, add
Code:
-lwpiutil
to your flags. We split out a lot of the functions we use across all of our C++ codebase into a separate library, that's where all those missing functions are defined.
Unread 08-01-2017, 12:40
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Code:
#include <ntcore.h>
int main() {
	return 0;
After you fix the build error, you'll find that this program won't actually set a value. All NetworkTables calls are non-blocking, so the program will exit before it has a chance to connect to the server. You'll need to put the PutString in a loop or add a few seconds delay at the end. Note you'll want a loop for image processing anyway.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 08-01-2017, 16:24
FRC #4635
Yes, thanks, I was able to compile and test it
Unread 09-01-2017, 11:53
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Hello all, I have been trying to compile ntcore and cscore on a raspberry pi 3 and can not figure out the issue. Whenever I compile with
Code:
g++ -std=c++0x -I/home/pi/ntcore/include -lwpilibutil -lntcore test.cpp -o test `pkg-config --cflags --libs opencv`
The error I get is:
Code:
fatal error: llvm/ArrayRef.h: No such file or directory
I was able to successfully build the ntcore libs by doing
Code:
./gradlew :arm:build
All I have in the cpp file is #include<ntcore.h> and #include<networktables/NetworkTable.h>
Any help is appreciated
Unread 09-01-2017, 14:32
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Code:
The error I get is:
Code:
Code:
You need to add the wpiutil include path "wpiutil/include" to your build command as well. Also you need to be linking with wpiutil, not wpilibutil.
One thing to note is that roborio builds built with ./gradlew :arm:ntcore:build will NOT work with a raspberry pi. They are completely separate architectures. We provide some (untested) artifacts for pi and other hf devices on our maven repo. Our recommendation for Pi is to download the 3 artifacts (cscore, wpiutil and ntcore) from our maven repo, and build locally on the Pi using those artifacts. You can find more information here regarding which artifacts to use and how to find the right ones for your specific device.
If you do want to build your own builds, download the repositories and run "./gradlew :arm:ntcore:build -PcompilerPrefix=" on the pi itself with nothing specified after the compiler prefix. That will trick the build system into building the arm artifacts with the built in compiler.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 09-01-2017, 15:12
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Thanks! I figured it out with your help!
