Go to Post Why follow when you can lead? - Elgin Clock [more]
Unread 08-01-2017, 15:00
2846 driver 2846 driver is offline
David Taylor
AKA: David Taylor
FRC #2846 (Firebears)
Team Role: Driver
Rookie Year: 2013
2846 driver can only hope to improve
Call me crazy, but there's a hidden op strategy
Hear me out here, because I think this strategy will crush in finals.
This is kind of like most of the events that First puts out. You have to go across the field and score on the other, while you are loading on the opposite side.
Now, I have read the rules thoroughly, and I think that defense is one of the best strategies that you can have in this years event.
Think about it though. Gears have a huge value to them. They make you think that shooting would be a waste of your time, practically. So why not create the ultimate gear robot and just crush everyone else and get those sweet RP?
Because, if you have a defense robot in your game, you are so screwed if you can't hold your ground.
You are allowed to hit those robots putting on those gears as much as you want (unless you pin them for more than five seconds :/) You can push them away from that pin and keep them at bay. The only saving grace they may have is the side bars, which don't protect them that much.
I think that this will be the most broken strategy, but most of my team doesn't, but we'll see at the regional competition.
Unread 08-01-2017, 15:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Call me crazy, but there's a hidden op strategy
I'll happily take my 8/18 ft/s 6-CIM drive train and smush you into my receiving zone. Game on!
GitHub
Unread 08-01-2017, 15:14
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
You might run into a problem with C08 there.
Originally Posted by 2017 Game Manual C08
C08. Don’t expect to gain by doing others harm. Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FIRST Robotics Competition and not allowed. Rule violations forced in this manner will not result in an assignment of a penalty to the targeted ALLIANCE.
Violation: FOUL. If egregious or repeated, YELLOW CARD.
<blue box>C08 does not apply for strategies consistent with standard gameplay, e.g. contacting an opponent while in your RETRIEVAL ZONE to retrieve GAME PIECES. C08 requires an intentional act with limited or no opportunity for the TEAM being acted on to avoid the penalty, e.g. pinning an opponent in your KEY such that they cannot help but violate G17.</blue box>
If you push me into your RZ and it's clear I can't avoid being pushed there, you should draw a C08 foul for forcing me to draw a foul that I otherwise wouldn't have.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 08-01-2017, 15:26
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
It's a statement about being able to do it.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 08-01-2017, 15:33
Ari423's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
In that case, I'll happily let you do that to get 5 points
2013: Programmer
Unread 08-01-2017, 16:46
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
Rookie Year: 2011
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Not a ref, but....
Don't put yourself into the position of having a ref need to make a split-second decision.
Let us say that the ref isn't looking directly at your pair of bots the entire time but is needing to be looking at another spot as well. When the ref focuses on your bots again, what he sees is you being in the retrieval zone no matter how you got there. Who do you think is going to get the foul? You put yourself into a risky position, you have to accept that risk.
Nate
Unread 08-01-2017, 17:11
BotDesigner's Avatar
BotDesigner BotDesigner is online now
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
Team Role: Leadership
Rookie Year: 2011
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Originally Posted by scca229 View Post
Not a ref, but....
This is call that you will rarely get called to the defensive robots favor. Last year a robot flipped us in our own courtyard. The ref still gave the opposing alliance scaling points when their robots smashed into our robot inside of its frame perimeter, significantly damaging our robot. The scaling points "won" the match for the other alliance.
I can see where the call came from though. It could be argued that the other robot was acting within standard gameplay when tipped our robot (unintentionally) as it attempted to get to the low-goal (as well as at the end of the match while trying to get to the batter.) Same call should be made if a defensive bot is trying to block access to a receiving zone and it is pushed into it.
2016, 2017 Colorado FLL Champions
2014 FLL North American Invitational, 1st place Strategy and Innovation Award
2014, 2013 Kentucky FLL Champions
2nd place Strategy and Innovation ward
FLL Team Automaticus Rex, Team Captain('11-'14) youth mentor ('15-'17) FRC Team 4418 Member ('14-') Design Lead ('15-16') Program Managment ('16-')
Last edited by BotDesigner : 08-01-2017 at 17:44. Reason: putting my thoughts diffrently
Unread 08-01-2017, 17:36
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
amesmich is an unknown quantity at this point
It is because of all this discussion and thought that I despise defense. I understand its part of the games but its not FIRST IMHO. Otherwise I would rater open it up to full contact and be more like battle bots. Bumping is ok with me but just getting in the way to stop a team from playing the game is silly in my opinion. I would rather just be able to have a function flip the offending bot over and be done with it. All or nothing. I realize I am in the minority here and many like the idea of defense and feel its important to the game. I disagree. I feel first provides enough challenges in the game to keep us occupied and silly bumping is remedial. Just an opinion I can respect the POV of those who do think its important. Either way its legal.
Unread 08-01-2017, 17:42
AKA: David Gedney
Rookie Year: 2011
Originally Posted by amesmich View Post
I despise defense.
I am a Denver Broncos fan and I take serious offense at your comment.
Unread 08-01-2017, 18:59
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Fyi regardless of how, why, or what state your robot is in. If you were in that courtyard at the 20 second mark any robot could touch you for any reason and they got an automatic scale
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 08-01-2017, 19:28
AKA: David Gedney
Rookie Year: 2011
That wasn't really the point of the post. The point was that although that situation was a textbook definition of a offensive robot forcing a defensive robot to commit a foul (there was no way that we could have avoided the foul after they forced a flip and then hit us within the last 20s), it didn't matter since the offensive robot was arguably attempting to act within standard gamplay and thus no G11 (or C08) call.
Unread 08-01-2017, 17:27
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Originally Posted by 2016 Rule G11
G11 Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of
Originally Posted by 2014 Rule G14
3.2.3.6 G14: Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FRC and are not allowed. Rule violations forced in this manner will not result in assessment of a penalty on the target ALLIANCE.
Violation: TECHNICAL FOUL
Originally Posted by 2013 Rule G18-1
3.2.3.10 G18-1: Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FRC and are not allowed. Rule violations forced in this manner will not result in assessment of a penalty on the target ALLIANCE.
Originally Posted by 2012 Rule G26
[G26] Strategies aimed at the destruction or inhibition of Robots via attachment, damage, tipping or entanglement of Robots
are not in the spirit of the FRC and are not allowed.
Violation: Technical-Foul plus Yellow Card
We have not played an official match of STEAMworks yet. In the reffing of the above years with the listed rules, however, what you're discussing was never the interpretation. (I say having reffed that exactly situation several hundred times under those rules and having coached champion defensive and offensive bots under the same.) If an offensive robot had a right to be somewhere or do something, pushing a defensive robot that put itself in the way was not at all a "strategy aimed solely at forcing the opposing ALLIANCE to violate a rule". The pusher's strategy is to "play offense", and the defense is just in its way. The foul is on the defense. The only time one of my ref crews has ever not given it to the defense is one case in which the defensive bot actually broke down in front of a protected zone, stayed there dead for a good chunk of the match, and an offensive bot went out of its to hit it repeatedly and then leave. When I coach, my rule is always Defend at My Own Risk.
You're of course free to Q&A this, but forwarning to phrase it carefully lest you provoke the dreaded Your FRC Overlords Do Not Comment on Hypothetical Situations response. (Myself, I wouldn't bother provoking them for such a perennial situation; this is by no means a new phenomenon unless you have an edge case in mind.)
Unread 08-01-2017, 16:57
JesseK's Avatar
FRC #1885 (ILITE)
This has come up many years before now. In the cases of protected zones, expect the referee to give the penalty to the person on defense. Especially if my team has only ever done offense, it is easy to say we're only pushing into our own zone and you getting a penalty as a result is not our intent - we simply want you out of our way and are doing what's within the rules to do it.
It will likely be Q&A'ed.
GitHub
Unread 09-01-2017, 09:34
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
6 CIMS? Wow. The stall current is 133 amps per motor, or 800 amps total. How do you keep from tripping the circuit breaker?
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
  #15   Spotlight this post!
Unread 09-01-2017, 10:29
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
6 CIM tank drives are perhaps the most common drive in FIRST.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
