Go to Post Might change next year. Read the manual then too. - Billfred [more]
  #16   Spotlight this post!
Unread 17-01-2017, 21:40
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: How Do you Climb the Rope?
775 do a nice job lifting the robot quick
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
  #17   Spotlight this post!
Unread 17-01-2017, 22:44
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Rookie Year: 2014
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Careful not to let them stall though they'll burn up quick.
  #18   Spotlight this post!
Unread 18-01-2017, 08:01
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Originally Posted by ICE_Bear View Post
What motors work to lift the weight of a robot? Of course some have to, but we are at a loss as to what we could use.
Shameless plug here. If you aren't sure what motor(s) and reduction to use for your climber (or any mechanism), check out the spreadsheet calculator I just posted here. It lets you vary motor type & number, force, and moment arm and calculates the reduction that will put the motor at peak power output. Then you can check the top speed and see if the chosen motor is strong enough or you need a stronger motor. Technically, any motor will lift the robot's weight if you gear it low enough, but it will be insanely slow if you choose to lift the robot with a throttle motor.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
  #19   Spotlight this post!
Unread 18-01-2017, 13:02
edong4273's Avatar
edong4273 edong4273 is offline
Team 2375's Very Own Dong
AKA: Edmund "Dong" Dong
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
edong4273 is on a distinguished road
I believe that our team is gonna try the velcro method, using loop side velcro as our rope and then having a drum on the robot that has hook side velcro.
I think we could be way overshooting what we need, but we are thinking of using 2 bag motors at a 100:1 reduction using a VersaPlanetary Gearbox from VEX.
Hi, I'm Edmund, most people call me Dong. I drive, wire, connect, build, edit, and do a little photo taking on the side.
2016-2017 - Vice-President of Engineering and Design of FRC 2375 "Dragon Robotics"
2015-2016 - Member of FRC 2375 "Dragon Robotics"
  #20   Spotlight this post!
Unread 18-01-2017, 14:16
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we are currently planning on a 1 inch drum powered by 2 bag motors at 25-1 and a 3-1 belt reduction
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
  #21   Spotlight this post!
Unread 20-01-2017, 09:03
Team 288's Avatar
Team 288 Team 288 is offline
Team 288 - Spare Parts
FTC #0288 (Spare Parts)
Team Role: Coach
Team 288 is a jewel in the roughTeam 288 is a jewel in the roughTeam 288 is a jewel in the roughTeam 288 is a jewel in the rough
Our team has done the calculations and we have decided to use the Bag Motor for climbing.
Charlie Blair
Electronics Instructor at Gateway Institute of Technology High School
Head Coach for FTC teams at Gateway Institute of Technology High School since 2005
Planning Committee Member, St. Louis Regional FTC
Mentor to Team 931 Perpetual Chaos since 2004
FRC Volunteer
  #22   Spotlight this post!
Unread 20-01-2017, 12:08
Chris is me's Avatar
AKA: Pinecone
Given the correct gear ratio and infinite time, any motor can lift any load.
There's an absolute minimum amount of time any motor could do any amount of work based on the motor's max mechanical power, assuming perfect efficiency and perfect gearing and everything like that. In reality you'll never get close to this speed but it's a good way to get a rough idea how much faster one motor can potentially be compared to another.
Some back of the napkin numbers: You have to lift a 140 pound (63 kg) robot (counting bumpers and battery) about 3 feet (1 meter). This is a change in potential energy of 618 Joules. The work required to do this is thus also 618 Joules (work-energy theorem).
Motor mechanical power is measured in Watts, or Joules per second. Here are some max mechanical power ratings for common FRC motors:
CIM: 336 W
Mini-CIM: 216 W
BAG: 148 W
775Pro: 348 W
So if we divide the work needed to lift the robot by the power of each motor, we will get the absolute fastest possible time that motor could possibly lift the load. Again, this in real life depends on any number of things that will make the real number fastest, so this is only useful as a basis for comparison:
CIM: 618 J / 336 J/s = 1.84 sec
Mini-CIM: 618 J / 216 J/s = 2.86 sec
BAG: 618 J / 148 J/s = 4.18 sec
775pro: 618 J / 348 J/s = 1.78 sec
What this tells us is, even if we get the perfect gear ratio for each motor, and a 100% efficient gearbox and everything, an optimally-geared BAG motor will take more than twice as long as an optimally-geared CIM or 775pro to climb.
So what motor should you use? Clearly, the higher the power, the faster you may be able to go if you get the gearing right. CIM style motors are generally more durable than fan-cooled motors like the 775pro, particularly if you end up stalling them for any period of time, so they are likely a safer bet. Aside from that, the CIM and Mini-CIM have much more power available than the BAG, so I would use at least one of those. The 775pro can work, but you have to be careful not to stall it.
More on gearing later if anyone's interested.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
  #23   Spotlight this post!
Unread 20-01-2017, 12:10
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Originally Posted by GeeTwo View Post
We're working four different prototype tracks for climbing. We figured out pretty quickly that securing the rope would be the fiddly bit.
  • "Keyhole" (knot)
  • "Hook Drum" (loop)
  • "Wringer" (plain end)
  • "LevelWind" (plain end)
All but "wringer" involve pulling the rope with a winch/drum/spool. Wringer is more like a continuous intake mechanism.
449 would like to assure you that securing the rope via the "hook drum" approach is actually quite easy.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
