Go to Post I might be a nerd, but I am definitely a pi freak! - Courtneyb1023 [more]
Unread 08-01-2017, 17:02
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
Having trouble Configuring OM5P-AC Radio
While using the FRC Radio Configuration Utility we ran into some problems.
*All other networking devices are disabled, ran in admin mode, pings were successful
While the load firmware worked fine, configuring the radio with just a team number failed with
"Bridge configuration failed: Failed to change IP address, please check for an adaptor with the address 192.168.1.51. Please ensure the bridge is connected o this computer and try again.
Any ideas?
Programmers, a species indigenous to robotics that can convert caffeine into code.
Unread 08-01-2017, 17:21
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Having trouble Configuring OM5P-AC Radio
Try an ipconfig /all from the cmd prompt indow to insure that all NICs are listed as Disabled except for the Ethernet port.
For example, here is what mine looks like after using the utility successfully:
Code:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : McLeod
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 2C-60-0C-67-B9-92
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::b04b:a66e:f912:1967%13(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.25.103(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Default Gateway . . . . . . . . . :
   DHCPv6 IAID . . . . . . . . . . . : 355229708
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-15-63-31-9C-AD-97-D1-AF-B1
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 9C-AD-97-D1-AF-B2
Tunnel adapter isatap.{8DB6A71A-AA73-4119-9A7F-73F61A29A6C6}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
But having the wireless Enabled like this breaks it:
Code:
   DNS Suffix Search List. . . . . . : home
Wireless LAN adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 9E-AD-97-D1-AF-B1
Wireless LAN adapter Local Area Connection* 13:
   Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
   Physical Address. . . . . . . . . : 9C-AD-97-D1-AF-B1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : 1x1 11b/g/n Wireless LAN PCI Express Half Mini Card Adapter
   Link-local IPv6 Address . . . . . : fe80::64ab:693f:e62c:cfe6%14(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.11(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Sunday, January 8, 2017 5:17:03 PM
   Lease Expires . . . . . . . . . . : Monday, January 9, 2017 5:17:03 PM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 261926295
   DNS Servers . . . . . . . . . . . : 192.168.1.1
Tunnel adapter isatap.home:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Unread 08-01-2017, 17:23
Rookie Year: 2015
They are
Unread 13-01-2017, 16:35
SpazMonkey214 SpazMonkey214 is offline
FRC #5740
SpazMonkey214 is an unknown quantity at this point
Code:
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Code:
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
So I am having this exact same error, but I don't really understand what you are saying here...can you try to explain it a bit simpler for me?
Unread 13-01-2017, 17:40
vScourge's Avatar
vScourge vScourge is online now
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
Team Role: Coach
Rookie Year: 2012
vScourge is on a distinguished road
He just means your driver station PC's wireless adapter needs to be disabled to configure the radio. Running ipconfig is one way to check that.
We had this problem this year. I had been in the habit of disabling the laptop's wireless via the physical button, but apparently that's not the same as disabling the wireless interface in Windows network configuration. Once we did that it was able to configure the radio successfully.
If you're on Windows (10 in my case) here's roughly how you get there:
- Hit Start, type "Network and Sharing Center" and run that
- Click "Change adapter settings" on the left
- Right-click the wireless adapter in the list, hit "Disable"
