Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 09-01-2017, 00:31
teletype-guy's Avatar
teletype-guy teletype-guy is offline
Old Fart Electrical Engineer
AKA: Gil Smith
FRC #0698 (Microbots)
Rookie Year: 2014
teletype-guy is a jewel in the roughteletype-guy is a jewel in the roughteletype-guy is a jewel in the rough
2017 software updates -- sheesh.
Hey folks:
I set up my roboRIO and laptop a few months ago with FRC 2016 stuff -- I am now now on day two and many hours of downloading and installing 2017 software.
An FYI for you:
1) DriverStation and other NI files:
- download the "FRC 2017 Update Suite," an 800+ MB monstrosity.
- first (pardon the pun), uninstall "National Instruments Software."
- Extract-All from the zip -- needs password: &Full$team^Ahead!
- run the setup.exe for it -- needs password from KOP: Mxxxxxx and then activation.
- there is a note: "If installing on Windows 8 or 10, the Microsoft .NET Framework 3.5
may need to be installed." My laptop is win 7 but you may need to do this if you have a win 10 machine.
2) roboRIO firmware update:
- disconnect ethernet cable from radio, and connect USB to laptop
- use browser (with SilverLight added) and go to 172.22.11.2 to get to roboRIO-698-FRC Sys Config page.
(I had no idea that a browser could talk to a usb device).
- login, username = admin, password = (blank)
- Update-Firmware with file cleverly-hidden at:
"C:\Program Files (x86)\National Instruments\Shared\Firmware\cRIO\76F2\roboRIO_3.0. 0f0.cfg"
(my roboRIO was already at this level, but your team's roboRIO may need an update).
3) roboRIO team-specific "image:"
- still connected via usb from above.
- run "C:\Program Files (x86)\National Instruments\LabVIEW 2016\project\roboRIO Tool\roboRIO_ImagingTool.exe"
- select roboRIO-698-FRC, Team Number box should also say (team-number), uncheck "Disable-RT-Startup-App,"
check "Format Target," select "FRC_roboRIO_2017_v8.zip," and click Reformat. This takes forever.
- after successful image dialog, press Reset button on roboRIO.
4) roboRIO java run-time-environment:
- "Whenever a new image is installed on the roboRIO (either when initially setting it up or
later if the image is updated or reinstalled) the Java runtime must be replaced."
- run C:\Users\USER\wpilib\tools\java-installer.jar
I had already downloaded it from Oracle, so I saved those steps and just deployed it to the roboRIO.
5) I had Eclipse Mars (4.5.2) installed with the 2016 WPILib.
- The 2017 library is compatible with Luna, Mars, or Neon, so I did not update Eclipse Mars.
- I ran an update from Eclipse (Help/Check-for-Updates) to get the 2017 WPILib library (2017.1.1).
This took three restarts and a couple of hours (their servers are likely getting slammed).
- Note that CAN Talon SRX support has been removed from WPILib and needs
manual lib stuff from CTRE.
6) Got a build exception:
[scp] Connecting to 172.22.11.2:22
[scp] Receiving file: /usr/local/frc/lib/User_Libraries.properties
[scp] Caught exception: scp: /usr/local/frc/lib/User_Libraries.properties: No such file or directory
So commented out part of C:\Users\USER\wpilib\java\current\ant\build.xml:
<!-- ************************************ gcs mod to get rid of build error since no lib exists
<deploy-libs libs.name="User_Libraries" libs.basedir="${userLibs.dir}" libs.deployDir="${libDeploy.dir}">
<libs.local>
<fileset dir="${userLibs.dir}">
<include name="**/*.so"/>
</fileset>
</libs.local>
</deploy-libs>
There is likely a more elegant way to fix this, but gotta move on.
Wow, that is some convoluted crapola.
Unread 09-01-2017, 00:50
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: 2017 software updates -- sheesh.
<libs.local>
</fileset>
</libs.local>
</deploy-libs>
This is not a build error, but merely an indication that no user libraries exist on the roboRIO.
Unread 09-01-2017, 01:01
AKA: Gil Smith
Rookie Year: 2014
Yeah, but I dislike getting text in red during the build.
We will probably never have a user library. The build script should be crafted to quietly-ignore when there is no library. Is there a better way to do that?
thx, gil
Unread 09-01-2017, 07:35
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
thx, gil
Note that if you intend to use a Talon SRX, NavX board, etc you will need to use the "user libraries" feature (and uncomment what you commented)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 09-01-2017, 10:50
AKA: Gil Smith
Rookie Year: 2014
Ahh, didn't think of that. We may use talons.
