Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Unread 09-01-2017, 16:18
vyroj vyroj is offline
FRC #5115
vyroj is an unknown quantity at this point
Baseline in relation to airship
Where's the base line in relation to the airship? From the diagram it looks a little before, but I can't find how much. Will a team that places a gear on the lift closest to the wall cross the base line?
Unread 09-01-2017, 16:22
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: Baseline in relation to airship
the gap between the baseline and the airship is small (I think about 1-2 inches). The specifically mention in the field tour videos that placing a gear on a lift does not necessarily mean you have crossed the baseline.
If you are touching the airship's face, you will be over the baseline, but a substantial segment of the lift is not behind the line.
As with most rules about lines, it is in your best interest to make it abundantly clear that you have completed the action in question.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 10-01-2017, 11:59
Labman Labman is offline
Labman
AKA: Jim Loftin
FRC #4564 (Orange Chaos)
Rookie Year: 2013
Labman is an unknown quantity at this point
I believe there is misleading information regarding the baseline position that needs to be clarified in Q&A. Official "field assembly" diagrams show the baseline to be 93.3 inches from the driver station wall, while the game manual states it is 94.4 inches out. Given the line is marked with 2 inch wide gaffer tape this probably means the game manual is referring to the middle of the baseline.
The field assembly diagrams show the base of the airship at 114.3 inches from the driver station wall, which is 21 inches farther away than the baseline. This places the baseline near the tips of the two barriers at the bottom of the airship tower, and about 9 inches in front of the tip of the spring peg. This means a robot putting a gear on the peg in the center position will cross the baseline.
The game manual shows the line correctly in pictures on pages 15,16 and 18, but has the line in the wrong position on pages 13 and 40. Comments made on the field tour video about the lift are also wrong, and I believe the tape the hosts were looking at was simply tape holding the carpet pieces together, not the green tape supposed to mark the baseline.
Unread 10-01-2017, 12:12
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
I'm not seeing the problem on page 13. The red baseline is hard to see and is mostly occluded, but the blue baseline is just in front of the airship. The baseline does appear wrong on pg 18. I suspect the baseline used to be closer to the alliance station and it was revised to be right at the front of the airship, and not everything was updated properly. I think the field tour video depicts what the game will be, and the errors in the field drawings and some manual pictures will be corrected.
Unread 10-01-2017, 12:56
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
From looking at one of the other videos, it appears to me that the neutral zone line is incorrectly placed. They must have lined up the edge of the airship with the incorrect neutral zone line, thus misplacing the airship.
Until the clarification comes out, I think we should assume the field drawings are correct.
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
Unread 10-01-2017, 19:31
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
Team update 1 addresses this. The drawing on page 18 of the manual v1 is correct. The baseline is bear the tips of the dividers on the airship and not directly adjacent to the base of the airship. Additionally the field tour video is wrong.
