Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Unread 09-01-2017, 16:31
nathanv's Avatar
nathanv nathanv is offline
nathanv
AKA: Nathan Vaniman
FRC #4984 (Bullseye)
Rookie Year: 2013
nathanv is a jewel in the roughnathanv is a jewel in the roughnathanv is a jewel in the roughnathanv is a jewel in the rough
(New)matics advice
Hi everyone!
This me and my team's fourth year, but the first year we decided to use pneumatics. More specifically we are using the Vex 3 CIM Ball shifters. Is there any advice anyone has to someone who has never tried pneumatics at all?
Your help is appreciated!
Unread 09-01-2017, 16:59
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
Rookie Year: 2011
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: (New)matics advice
I took a class on Pneumatics/Hydraulics this past summer, and my advice would be this: don't over-complicate things, but make sure you learn symbols. Draw your circuits out before trying them. Pneumatic understanding is something that can potentially be picked up very quickly. Don't be afraid to play around with your resources, but understand why certain events happen. Also, use youtube. There are tons of videos and tutorials out there.
Unread 09-01-2017, 17:12
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Use these manifolds (http://www.vexrobotics.com/vexpro/pn...manifolds.html) they are a godsend. Don't use double solenoids unless you have to.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 09-01-2017, 17:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
But if you use single solenoids, make sure that you pick the correct position for the cylinder as your default!
Unread 09-01-2017, 22:13
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
We use mostly double solenoids. Last year, everything fit the model. Intake arm up and down, cheval/portcullis wedges up and down, shifting up and down (yes, vex 3-cim ball shift gearboxes).
So if you have something like shifting, it doesn't make sense to use two single solenoids when you can simply use a double solenoid.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 09-01-2017, 22:17
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
Why would you need to use a double solenoid for shifting?
Unread 10-01-2017, 04:08
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I don't think you understand what "single solenoid" and "double soleniod" means. It doesn't mean that a single solenoid only has one output. It means that when you apply power to the solenoid, one of the outputs gets air and the other doesn't. When you don't apply power, a spring returns the solenoid shaft and the output switches ports. This compared to a double solenoid, where a second solenoid forces the return of the inner shaft, not a spring. For a standard double solenoid, one solenoid is on and the other is off at any given time. Otherwise either the solenoids will be fighting each other or the shaft will be free to slide around and change outputs at will. You can see whether you're using a single or double solenoid easily because a single solenoid has one pair of input wires where a double solenoid will have two pairs. In FRC (as far as I've seen), there is generally no reason to use more complicated double solenoids over single solenoids unless you are working with 3-position solenoids, in which case you can't use the manifolds posted above either.*
*That isn't to say that you can't**, just that it usually isn't necessary.
**I have a number of times because we had them in storage. They work fine and are basically the same to program. They are just a bit more complicated electrically, more places for things to fail, and more expensive.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 10-01-2017, 04:10
Ari423's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
2013: Programmer
Unread 10-01-2017, 05:18
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
Rookie Year: 2014
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
In 2015, we used double solenoids for things like the ingestor arms so that they couldn't close into a stack when the match ends but start closed if we wanted. We also used one on the arm tilting mechanism since we had to start with the arm tilted back but don't want it to change position when the match ends.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 10-01-2017, 08:25
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Good morning! I'm a former member of FRC 225, and still an active FTC mentor.
Through FIRST, I landed a job with a hydraulics, pneumatic, and automation company. If you have any questions on parts, terms, setups, connectors, anything, I'd be happy to work with you to get your questions answered. Please feel free to send me a PM or just talk here.
Some suggestions:
1. Buy a tubing cutter. For the fittings used in FRC (Push-to-connect), the ends of cuts have to be perfectly square to seal.
2. Buy quality tubing, and parts. Freelin-Wade, the default supplier for FIRST tubing is a really solid company. I'd also recommend Norgren for fittings.
3. Understand your terms. You have air cylinders, who's force is decided by their bore (Diameter) and the distance they work over, called the stroke. You can have a double acting cylinder that needs air to move it both ways, or a Single Acting that will retract if the air pressure is removed. You can even have a Reverse Single Acting, which will extend with air pressure removed.
4. Understand when and where to use pneumatics. It's not always the right choice. Air actuators are smaller, lighter, and faster than electric in most cases, but you only get 2 (Sometimes 3) positions. You get better granularity with electric.
5. Understand your solenoids. Use Single-Acting solenoids when you want an item to revert to a default state on power-off. Use a double acting if it's important to stay in the last state on power off.
Above all, stay safe. Air pressure can be extremely violent and dangerous if you're not expecting it, and sometimes even when you are. Loose air hoses can whip through the air, air tanks can explode if damaged, cylinders can move faster than you can see with enough force to break bones.
If you have ANY questions, please ask! There are no stupid questions.
Unread 10-01-2017, 12:11
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
We used a double solenoid for shifting because we wanted to use pneumatic pressure for both shifting directions rather than relying on a spring inside the cylinder. Specifically we used very small pancake shifters. To use a dual port cylinder like this, the double solenoid is the way to go.
Unread 10-01-2017, 12:34
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
I don't think that's correct. As Ari423 explained above both single solenoids and double solenoids can charge both sides of the pneumatic cylinder and neither setup requires a return spring in the cylinder. The only practical advantage of a double solenoid in FRC is that they won't return to a default state when the robot is powered off which can be useful in certain situations but certainly not shifting.
Unread 10-01-2017, 12:38
AKA: Wren Hensgen
You're confusing the acting of a valve (Sprung or unsprung) with the porting of a valve. A 5/2 valve will supply pressure in both actuation directions, while a 3/2 will only supply it in one.
The 5 or 3 refers to the number of input or exhaust ports a valve has, while the digit after the / refers to the number of positions it has.
Unread 14-01-2017, 00:50
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
If you'll excuse bad diagrams finger-drawn at 1am, here's how a double solenoid does shifting
and
Here's a single solenoid connected to the same shifter
A spring is needed since there can only be pneumatic actuation on one side. We wanted pneumatic actuation on both sides, so we used a double solenoid.
  #15   Spotlight this post!
Unread 14-01-2017, 04:57
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
*snipped 2 images*
*snipped 1 image*
This is a spring return single acting cylinder.
A single action solenoid can power a cylinder. A single solenoid internally has a valve, a spring, and a solenoid. When the solenoid is not powered, one pneumatic output is connected to pressure, while the other is connected to atmosphere. Think of this as the default state, the spring keeps it there.
When the solenoid is powered, the solenoid pulls the valve to the other position, against the spring. the pneumatic connections are reversed. The bonus is when power is cut (including at the end of a match*), the valve returns to it's original state since there is nothing holding the spring back.
*= Not certain, depends on how WPILIB and the PCM are implemented. It should say in the source somewhere..
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
