Go to Post Why does kick off take so long to get here but ship date comes toooooooooo fast? - Steve W [more]
Unread 03-12-2002, 22:10
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Stang-Sense
I was just wondering, I heard about some of the engineers on my team talking about some thing called "Stang-Sense" that was used by the Wildstangs in past years to do some funky detection stuuf with the motors So I was wonderign if any body on CD knew a little bit more about how exactly this " Stang-Sense" actually functions any info would great help. I all ready checked White Papers and there was nothing in there on it, just so you know. Thanks and have a nice day and a better one tomorrow
P.S You can IM me if its eaiser to talk about: Bldrngmn1
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 03-12-2002, 22:39
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
It's a current sensor that monitors current draw. Useful for telling when the fuses may blow, or when the main breaker may trip.
The schematic was posted somewhere around here.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 03-12-2002, 22:47
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Wheelman,
Stang Sense is our name for a current monitoring system we used on this years robot. It is capable of monitoring the current supplied to all six of our drive motor speed controllers through the dashboard port of the Operator Interface. Since the robot battery voltage is also available in the dashboard stream we monitored that as well. We were able to pass the stream to a color palm pilot that would change colors on two displays to show normal(green), caution(yellow), or warning (red) conditions of current. One display was an overhead of the robot showing the motors as colors. The other was a bar graph display of each motor. Since the palm was able to store the data in each match with a rough clock tick, we were able to analyze high current activities and warn drive team and strategy of risky behavior during matches. This system allowed us, during building phase, to recognize the new FP motors and the change in power curve. With a portable version, we were able to analyze problems on other robots as well.
We offered to connect up to problem robots at both Midwest Regional and Nationals. All in all I think we analyzed 20-30 robots and these are some of the problems we were able to help correct. Dead motor in a multi-motor drive system, locked transmission, binding bearing in a steering gear, excessive voltage drop in wiring during operation (led to change in electrical layout), excessive current while turning (typical for tank drive with high friction wheels), inefficient gear train, tripping resettable breakers, slipping clutch, and assorted wiring errors, bad crimps, loose wires and high resistance connections.
This system has been discussed here before so there is probably stuff in the archives. There is also a link on our website which is in the process of changing over to a new server. Try wildstang.com
Good luck all
Al
WB9UVJ
www.wildstang.org
________________________
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
http://www.wildstang.org/ws/Inventor...schematics.asp
www.wildstang.com has been down for a while... DNS trouble, I'm told...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 03-12-2002, 22:53
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
Yeah the stang-sense, me and my teammates are trying to design something similar. So far we've found a ciruit to do the measuring. If it works I'll post a schematic. By the way, I looked at the Stand-Sense schematics, could be my lack of electrical knowledge but I couldn't really follow it. Maybe some documents would help it. I plan to have ours output on control panle to warn us if it's gonna blow.
Soldering Away, (And most likely burning off my hand!)
Matt
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 04-12-2002, 10:59
Unsung FIRST Hero
Rookie Year: 1996
Ask questions about the schematic and I will answer.
Al
WB9UVJ
www.wildstang.org
Unread 04-12-2002, 11:29
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Al, Nate Troup and myself all regularly read this board and were all extensively involved with designing the hardware and software that makes up StangSense. Unfortunately we haven't really documented much of it anywhere except for the schematics, but we'd all be happy to answer questions.
Unread 04-12-2002, 17:59
Matt Krass's Avatar
AKA: Dark Ages
Well if your inviting me to, I was wondering, how did you measure current? I found a simple circuit that should do it but not sure, working on a test breadboard version at moment. What circuit did you use? Is it documented anywhere?
Thanks,
Matt
Matt Krass
Unread 04-12-2002, 23:30
Unsung FIRST Hero
Rookie Year: 1996
Matt,
When the site comes up the schematic is at http://www2.wildstang.com/2002/inventor/schematics.asp
The archive discussion is at http://www.chiefdelphi.com/forums/sp...=&postid=99762 and you will find a full description there.
The IC we used is from Maxim, MAX 4172, it is called a "high side current monitor" and can be purchased from Digikey. The downside is it's only available as a surface mount package. Digikey sells header boards that accept the surface mount package and converts it into a SIP you can insert in any .100 center circuit board or socket.
The Maxim 4172 is designed for monitoring current in battery charge circuits and is intended for a single power supply. It measures the voltage drop across a very small resistor and converts that and amplifies it to a suitable voltage. We used a 1 foot long piece of #10 wire as the resistor (.001 ohm)which turned out to be a good compromise since it was available for no cost, we were already using it as part of the robot (speed controller wiring per robot handbook)so there was no weight increase and it didn't need to be in the custom circuit box. The whole circuit except for programming interface fit inside the required box and a palm pilot was a valid device for use at the player station to view the dashboard output. We do owe a full explanation so that might be a future white paper. I will contact the other folks and see if we can't put something together.
Let me know if there is anything else we can help with.
Al
Al
WB9UVJ
www.wildstang.org
Unread 05-12-2002, 18:02
Matt Krass's Avatar
AKA: Dark Ages
Thanks, we are going to try the MAX 4172 IC, but what is part number for the ehader boards? We'll need those to build circuit. TIA,
Matt
Matt Krass
Unread 05-12-2002, 18:09
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Rookie Year: 1996
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Originally posted by Al Skierkiewicz
Matt,
Don't count on that happening any time soon, we're having problems getting our domain name back from our old ISP For now the web site is at http://www.wildstang.org/ and you can get the schematics at http://www.wildstang.org/ws/Inventor...schematics.asp as Jim said.
Mike
Unread 05-12-2002, 18:28
Software Engineer
Rookie Year: 1995
The Digikey part number is 33108CA-ND. There's a good picture of it here. Be warned, though: those pads for the MicroMAX version of the 4172 are really small. You will need someone who is excellent at surface-mount work to solder the 4172 to the header board. The pads on the header board lift off very easily.
Unread 05-12-2002, 19:05
Matt Krass's Avatar
AKA: Dark Ages
Thanks, I know someone who should be able to do it.
Matt Krass
Unread 16-01-2003, 20:15
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
exactally how did the multiplexing thing work? also what is the advantage of using the MAX4072 instead of the 4170 or MAX4071, with the internal reference?
1139 Alumni
  #15   Spotlight this post!
Unread 17-01-2003, 07:47
Unsung FIRST Hero
Rookie Year: 1996
Rickertsen2,
We chose the MAX4172 because it was simple, low parts count, and available from Digikey. We only needed to perform a high current to voltage translation that had a response that was good enough to follow the current pulses that are normal load currents for the input to the speed controllers. Remember that the speed controllers are rapidly turning on and off (varying duty cycle) to simulate variable voltage/current to the motor. The trick was getting a sensor to use for the input. The circuit as you have seen is designed to measure across a known length and width of printed circuit trace.
Matt Krass,
There is a quick trick for soldering flat packages. Use a small iron and tin the pads of the circuit board first. Then it is a simple matter of touching the soldering iron to the lead of the IC long enough to just melt the solder underneath and you are done. Repeat for each lead. Of course there is always the solder paste, reflow method if it's available.
Al
WB9UVJ
www.wildstang.org
Threads getting too long to make sense of Ken Leung CD Forum Support 22 05-05-2005 01:14
Picker Or Pickee archiver 2000 54 23-06-2002 22:26
We Rejected Wild Stang archiver 1999 5 23-06-2002 22:15
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
Controller Simulator Jay Programming 14 03-04-2002 02:04
