Go to Post FRC: more like the real world than we could ever want. - efoote868 [more]
Unread 09-01-2017, 19:20
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Staying within volume with multiple extensions
Lets say I choose volume A, 36 x 40 x 24 for example.
My frame perimeter + bumpers is small, it fills a 26 x 40 footprint. Now I can have an appendage that extends 10" beyond the bumper on either of two sides after the match starts
Can I do this on either side of the robot as long as I retract on one side before extending on the other side? Does it make a difference if I have only one appendage that is capable of reaching out in either direction but not both, vs two appendages that I assure via software or a hardware linkage that only one will be deployed at a time?
It seems that the 'volume' of the robot for an undersized bot (at least in horizontal dimensions) is ambiguous, so how does it apply to rule G28 regarding affecting fuel outside the volume of the robot ?
I would assume the vertical volume of the bot extends above the bot, not below the wheels, but who is to say, especially while climbing?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 09-01-2017, 19:31
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Team Role: Mechanical
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Staying within volume with multiple extensions
Blue box for R03
Expect to have to demonstrate a ROBOT’S ability to constrain itself per
above during Inspection. Constraints may be implemented with either
hardware or software.
You would have to prove to inspectors that only one side can be deployed at a time.
As for the vertical volume, R03 does not specify being applicable in only one direction, so anything that extends below would be subject to it, and also
R23. BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained
between the floor and a virtual horizontal plane 7 in. (~17 cm) above the floor in reference to the
ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 09-01-2017, 19:36
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
That's fine, it doesn't make a difference. When being inspected the inspector should ask for a team to do a dry run and check for intentional expansion outside the volume. Refs and inspectors should also watch the robot on field to make sure it does not violate the rules. This is how we (inspectors) treated a robot last year that had a motor driven multi joint arm that could easily extend outside legal limits.
The volume should be considered dynamic (except that you cannot switch between the two volume options) it's up to the ref to judge your current volume. The volume is virtually transposed in reference to the robot sitting on a flat floor and should remain parallel to your frame perimeter. Extensions below the wheels should be fine.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 09-01-2017, 20:39
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
As long as the bumpers are not articulated and the bumpers remain in the bumper zone.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 09-01-2017, 22:43
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
The "height" includes extensions below the wheels (jacks).
R23: This measurement is intended to be made as if the ROBOT is resting on a flat floor
It does not say "resting on its wheels on a flat floor". If the extensions go below the wheels, then the robot will be resting on the extension on the floor. Note: The extensions would then change the Bumper Zone relative to the wheels.
