Go to Post of course, like anything, there is big difference between "can" and "should" - ratdude747 [more]
Unread 09-01-2017, 23:20
ShammyWhammy ShammyWhammy is offline
FRC #3571
ShammyWhammy is an unknown quantity at this point
Is the Boiler worth it?
I can't seem to figure out a reason why you'd wan't to go for the steam over the gears. You gain points in a much more efficient manner with the gears. If you get all the rotors started you get a minimum of 120 points with a qualification point in teleop. With the steam, you get something like 40 points and a ranking point for 120 balls shot in the high goal. With a processing rate of 5/s, that comes out to 24 seconds of just processing and that's not accounting for the chance of you missing and collection time. It just seems extremely inefficient compared to the gears. Is there a maximum on the kPa you can have?
Unread 09-01-2017, 23:26
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
Rookie Year: 2013
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Re: Is the Boiler worth it?
There are two main answers:
-In higher level (and perhaps slightly above average) matches, you don't need all robots on gears. You only want to devote the minimum resources necessary to the gears, and capitalize in other ways for points (balls or hang).
-You get a ranking point for 40kPa. Ranking points are immensely valuable, as I'm sure that you've recognized if you've looked at FIRST STRONGHOLD. This RP might even be achievable in autonomous (if you are a high goaler with a speedy shot) by triggering a hopper and shooting, as the point values are boosted. Regardless of if you don't quite make it, this gets you in close proximity to the needed 40kPa.
tldr; Ranking points are important, slightly above average alliances don't need all three robots on gears.
Additionally, while the kPa visual counter maxes out, their is no maximum to kPa you can earn.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 09-01-2017, 23:32
FRC #3571
So then can you earn an additional ranking point if you can manage another 40 kPa?
Unread 09-01-2017, 23:37
g_sawchuk's Avatar
Hmm.
FRC #4476
Rookie Year: 2013
No, there is only an RP for when you hit 40 the first time (discussed on other thread).
Unread 09-01-2017, 23:34
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
The fastest way to get the boiler up will be to dump 50 balls into your robot from a hopper and stream them into the high efficiency goal during auto. Not easy, but fast. I think some teams will do this; i.e., the teams that go to Einstein.
Richard Wallace
since 2003
Unread Yesterday, 11:06
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
Rookie Year: 2012
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
I think that far more teams will be able to do this than the Einstein teams. I truly believe that 3-10 teams per regional will be able to do this. Maybe not in week 1 or 2, but by champs, I believe it will be common.
In regards to whether or not the boiler is worth it: Yes, in the right situation. Say your alliance has time to score 10 gears. So you score 10 gears, then climb. You've gotten 3 rotors spinning with 0 fuel. But you had 3 rotors spinning at 7 gears - you've completely wasted time scoring 3 gears because those 3 give you a grand total of zero points. Whereas if the opponent alliance had the same gear scoring speed, but stopped at 7 and scored fuel for the remainder of the match, then climbed, that alliance is victorious. And also maybe got an extra RP.
I can't speak for whether or not the boiler is "worth it" in eliminations. But the boiler is an incredibly easy way to get a RP during quals, especially with a strong autonomous.
Unread Yesterday, 19:24
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
There will not be a single regional in which at least 10 teams score at least 50 high goals in auto.
Unread 09-01-2017, 23:38
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Also, the gears have a diminishing return. Assuming all in teleop:
Rotor 1 = 1 gear = 40 pts/gear (60 in auto)
Rotor 2 = 2 gears = 20 pts/gear (30 in auto)
Rotor 3 = 4 gears = 10 pts/gear
Rotor 4 = 6 gears = 6.667 pts/gear
Additionally, you have to deliver all but 1 gear, so that's 12 gears to deliver through the match, which may take a little while (average rate is about one every 10 seconds in teleop to get all 4 rotors). Factor in defense of various types, and you'll need to be pretty good at gear transport to get 4 rotors turning.
Oh, and if you deliver 11 gears, you may as well have stopped at 6.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-01-2017, 09:03
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
There is one small but VERY important mistake here.
Rotor 4 = 6 gears = 6.667 pts/gear + 1 RP (qualify)
Rotor 4 = 6 gears = 23.33 pts/gear (playoff)
Unread 10-01-2017, 09:23
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Rookie Year: 2013
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
One thing I've realized over the years is that relying on your qualification partners can be risky business. Unless you have a constant stream of information from your scouters throughout the tournament, many teams over estimate their ability. That said, we have been evaluating how our team can hold our own in matches.
It is significantly more feasible for a single robot to max out the pressure on the boiler, only needing one or two cycles depending on the robots fuel capacity and accuracy. A single robot is going to have a very hard placing the 12 gears needed to get the rank point for the rotors on its own. Assuming one gear could be placed in auto, that leaves about 10 second per gear cycle, while still leaving 15 seconds for a climb. A robot is going to have to move quick and avoid all defense. A boiler robot can guarantee the rank point on its own and has more protection while doing so. The tricky part is determining how many rotors need to be spinning to get enough points to guarantee the win as well. Arguably winning is more important than losing but filling the boiler. But being able to solo fill the boiler is also a very valuable alliance partner in playoffs.
Unread 10-01-2017, 09:24
DAlitz's Avatar
DAlitz DAlitz is offline
AKA: Dave Alitz
FRC #3042 (Cobalt Catalysts)
Rookie Year: 2016
DAlitz is an unknown quantity at this point
Don't forget, to deliver a gear you'll almost always have to traverse the field. Fuel will be available in the hoppers and likely on the ground. Less travel time.
The boilers also have no upper limit. Once you've delivered 12 gears your done with them. If you don't have anyone in your alliance working with fuel you've capped the total number of points possible.
Unread 10-01-2017, 10:10
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by DAlitz View Post
<Snip>
<snip>
"likely on the ground'? That's an understatement.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 10-01-2017, 10:22
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
This is my reasoning for doing boiler. I expect that in higher level play we will see 4/4 rotors spinning in most matches for both teams. That means that the boiler and climbing are going to be what decide the matches.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 10-01-2017, 14:34
ldsedam's Avatar
ldsedam ldsedam is offline
AKA: Drew Sedam
FRC #2137 (TORC)
Rookie Year: 2012
ldsedam is an unknown quantity at this point
The fuel is the only method of scoring in this game that has no limit. In higher level of play, the rotors will get capped out with some time left. After this, the determining factor is the fuel. Whichever alliance can put in the most fuel into the boiler is how the winner will be decided.
  #15   Spotlight this post!
Unread 10-01-2017, 16:30
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Gears are bursts of points, boilers can get you points in the background while you go around and do other things. Both are worth it, you should ask what you want to prioritize more. In all honesty I look at all the objectives on the field and most of them can be accomplished with minimal moving parts. I imagine some of the best robots out there are going to be insanely simple designs augmented with active mechanisms to make them run more efficiently but that is a different conversation.
This game kinda reminds me of cookie clicker, Star Craft or Age of Empires in regards to resource management. If you only do one or the other you are going to have a ton of down time where you aren't scoring and if you aren't scoring you still need to be doing something.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
