Go to Post It's important to know that it isn't always best to have biggest machine out there. - Quatitos [more]
Unread 10-01-2017, 22:12
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Polycord Conveyor Belts
For the following questions, assume a 20" wide conveyor that is 20" long. There would be 8 strands of 1/4" polycord acting as the conveyor.
How fast can a polycord conveyor belt be run? How is that speed effected by number of turns the conveyor makes? How do you frame your conveyor and how do you keep the belts in line? What does the polycord roll around (what diameter)? What durometer polycord works well with the Fuel if anybody has tested that? Does a single run of polycord with a stationary wall work better, or does 2 powered runs of polycord work better? Does the conveyor require a significant amount of power to run, especially when loaded to capacity with Fuel?
Probably a lot of unanswerable questions, but I'm just looking for asomething much information about conveyors as possible, because I've never built one before.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 10-01-2017, 22:37
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Re: Polycord Conveyor Belts
I've used polycord flat belt for a robot combat weapon drive spinning at 10000+ RPM. No issues. I always recommend flat polycord over round as it is much easier to center by using a crowned pulley which can be easily made by wrapping electrical tape on your roller. (watch this! https://www.youtube.com/watch?v=6sM0Qjumyro)
This document has some good info on one sided conveyors vs two sided. (http://files.andymark.com/ManiupulatorDesign.pdf)
Conveyors generally don't require tons of power, usually the belts will slip on the game piece before the motor stalls.
The amount of turns don't really affect the power necessary.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 10-01-2017, 22:48
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
These are some awesome resources, thank you! What specs would you reccommend on the flat belt? I'm not sure about durometer, width, thickness etc.
Reveal Video
White Paper
Unread 10-01-2017, 22:55
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
McMaster 6075K15
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 10-01-2017, 22:57
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Originally Posted by Knufire View Post
McMaster 6075K15
Yup, this is good stuff. Other thicknesses/widths in the same family are also pretty solid. Experience with this stuff in 2012 was wonderful.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 10-01-2017, 23:24
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
McMaster 6075K15
How have you joined it. do you need a $450 kit to do it?
Unread 10-01-2017, 23:28
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
It's far easier to join that round belt. My favorite way is to use a hot plate (a pan on a stove works well too) set to max power. Melt the ends and then press them together. Once the urethane solidifies wait at least 10 minutes before applying tension. You can melt the faces of the belt together too if you have trouble with the ends. I've never had a properly joined belt fail.
Unread 10-01-2017, 23:31
Billfred's Avatar
Billfred Billfred is offline
The 2815 method:
Measure, cut about 3-5% short (IIRC).
Set both ends in a piece of angle, with a second piece of metal to steady it.
Melt with a small torch or lighter, press together.
Clamp tight with another piece of angle for more straightness.
Wait 10 minutes.
Try to break it by stretching; if the belt fails, you did it wrong. Try again.
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 10-01-2017, 23:33
Rookie Year: 2010
We made a custom aluminum tip for a large 240W soldering gun and a hinged block with a slot. Heated the ends up, pushed them together in the slot and close the top of the block on them to keep them aligned. Wait until they cool and remove.
The block (along with two tiny vice grips and some other misc hardware) made a nice little toolkit that allowed us to weld these together on the robot under tension. Fixing broken belts without having to remove the roller was a big plus.
Unread 11-01-2017, 19:31
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
These are some great resources, will have to send that video along to our students.
McMaster 6075K15
Thanks for the reference.
Really great thread, any other tips are appreciated for those of us who haven't done belting in a while (or ever).
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 13-01-2017, 14:25
wmmc wmmc is offline
AKA: Melvin Wang
FRC #6135 (Arctos)
Team Role: Student
wmmc is an unknown quantity at this point
Do you think that using those belts in a vertical conveyor against a stationary wall (as OP mentions) will be effective at "pulling" the fuel balls upwards? I haven't seen a robot that has had a vertical flat belt conveyor.
Unread 13-01-2017, 14:31
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
It should be fine. Flat belt typically preforms as good as or better than round polycord. A notable robot who used that setup was 341 in 2012.
Unread 13-01-2017, 14:33
AKA: Nick Aarestad
We were close to vertical in 2012. You'll want to prototype with difference compressions on the ball to figure out what works the best. I'm not sure whether it would be superior or inferior to a vertical round polycord system though, as I've never had a chance to directly compare the two personally. I also have only worked with it using the foam balls from RR which are not really directly comparible.
So I guess, direct answers: probably, with sufficient design and prototyping. There's also a difference between something working and something being truly excellent, and I'm not sure where this would fall.
tumblr | twitter
VEXU UMN (2015-??)
Unread 13-01-2017, 14:59
Rookie Year: 2010
469 did a conveyor like this with timing belt in 2012. If anything, the flat polycord is more grippy.
