Our gears mesh perfectly!
Unread 10-01-2017, 22:45
Glacier's Avatar
Glacier Glacier is offline
The Bearded One.....
AKA: Levi Cagle
FRC #3959 (Morgan County Mech Tech)
Team Role: Webmaster
Rookie Year: 2015
Glacier is an unknown quantity at this point
What do y'all think is the best method of transporting fuel via different systems?
Looking back at past competitions the Archimedes screw or a screw like device that channels game pieces in a rotating fashion within a robot, has proven to be effective in storing and scoring balls. With the new volume constraints is it highly probable to be used?
Ever learning...
Sent from my iPhone using Tapatalk
Unread 10-01-2017, 22:54
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Re: What do y'all think is the best method of transporting fuel via different systems
Personally I don't think so. The screw type hopper shines when you have an abundance of vertical height and space which was available in other games (2009,2006,2012). My big issue with the screw system is it requires indexing/funneling the balls before they enter the screw system unlike other hopper designs (1114 2006 2009, 254 2012,341 2012). This can be very difficult to do without jamming. Additionally the screw hopper cannot double up as a collector for balls from the loading station.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 10-01-2017, 23:48
Canon reeves Canon reeves is offline
FRC #4490
Rookie Year: 2013
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
I think a hopper would be pretty effective. The balls are very small relative to the robot, so a large box could hold quite a few balls without needing to index them before they are put into the hopper. I think gravity fed hoppers are a lot harder to design without jamming than actively fed hoppers. Yes it is possible, but it requires non symmetrical choke points, which tend to eat up space. I've been thinking about a hopper with a plexiglass bottom and several polychord belts that run at high speeds towards the flywheel elevator. This would allow controlled feeding that doesn't rely as heavily on gravity. It also means the floor could be almost flat, saving space. This would work well with a 3-4 ball wide flywheel. Last year's vex game was shooting similar sized balls, and the most prominent design was to use a flywheel with a lot of mass, a decent amount of contact time, and very little compression.
Unread 11-01-2017, 00:03
dmaggio744's Avatar
dmaggio744 dmaggio744 is offline
Steely Eyed Missile Man
AKA: Drew Maggio
FRC #2869 (Regal Eagles)
Rookie Year: 2015
dmaggio744 is on a distinguished road
If you ask me, agitators will also be important this year. Ri3D 1.0 tried a wheel, Archimedes screw, and blender, and neither seemed outstandingly successful. (the blender won in the end)
