Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 11-01-2017, 10:57
svince svince is offline
FRC #3606 (Bear Metal)
Team Role: Mechanical
Rookie Year: 2013
svince is an unknown quantity at this point
Mecanum vs. Tank Drive?
Our team is currently trying to decide between using a mecanum drive and a basic tank drive from the KOP in order to effectively make a cycle for placing gears. Would mecanum be a viable alternative because of the precision boost, or would tank style overpower us in our runs across the field to the point where it isn't worth the change in style?
Unread 11-01-2017, 11:09
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Mecanum vs. Tank Drive?
Mecanum
Pros: precise maneuvering
Cons: requires precise robot mass distribution in order to work. Also harder to program
Tank
Pros: easy to build
Cons: go up to feeder station. You're not aligned. Drive back and turn. Go up again. Still not aligned. Drive back and turn again...
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-01-2017, 11:13
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Tank.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 11-01-2017, 11:32
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
Rookie Year: 2011
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
A tank drive will give you the ability to literally push your way across a field and hold your ground if you need to. Mecanum is a really good drive system if there's a reason. The field this year is flat, making mecanum a viable drive system to pursue. With limited visibility though, there is a possibility of you getting into situations such as being pushed around (perhaps while on the way to get fuel or gears), and not even recognizing what's going on. 2014 was a strong year for mecanums because the field was flat and clear. 2015 was a good year because there was no defense. This year, on the other hand, I'm not so sure. My vote is for tank.
Unread 11-01-2017, 11:35
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Unread 11-01-2017, 11:41
Lord Basket's Avatar
Lord Basket Lord Basket is offline
President & Drive team coach
AKA: Parker
FRC #1719 (The Umbrella Corporation)
Rookie Year: 2014
Lord Basket has a spectacular aura aboutLord Basket has a spectacular aura aboutLord Basket has a spectacular aura about
The biggest downside by far to mecanum drives are that they can and will get pushed by everyone. In a game like Steamworks where there's an open field which most robots will regularly have to traverse, and where teams without functioning devices have nothing to do other than play defense, that one downside overshadows any and all minor advantages that mecanum drives have.
Unread 11-01-2017, 11:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Originally Posted by euhlmann View Post
Mecanum
Not really, on either. In 2013 we did mecanum. Using the canned mecanum drive class, it was no more difficult than a four motor tank system. (OK, an extra joystick axis). We ran it on our prototype robot, "woody", which had at least 4x the weight on one corner wheel than the opposite, but within a half hour of driving practice, drivers had learned to compensate so well that they weren't doing it consciously.
Actually, woody was the only robot we have ever built that I have over an hour of stick time on, due to a demo I did at work. All I recall was having to account for a slight pull to one side.
Last edited by GeeTwo : 11-01-2017 at 13:25. Reason: Fixed quote, added second paragraph
Unread 11-01-2017, 11:59
ldsedam's Avatar
ldsedam ldsedam is offline
AKA: Drew Sedam
FRC #2137 (TORC)
Rookie Year: 2012
ldsedam is an unknown quantity at this point
I would strongly recommend not using mecanum in any game where defense will have the potential to have an impact. The ability for a robot to be completely shut down by defense with little effort is a huge drawback. There is a reason why there has never been a mecanum drive on Einstein (Except 2015).
Unread 11-01-2017, 14:58
chandrew's Avatar
chandrew chandrew is offline
Strategy Sun Tzu
AKA: Andrew Chan
FRC #1410 (The Kraken)
Team Role: Tactician
Rookie Year: 2013
chandrew is an unknown quantity at this point
Do you have experience building a mecanum drive? If not, I would definitely build the KOP chassis.
The clear field is great for a mecanum, however you want it done quickly so your drivers can practice driving with defense.
Andrew Chan
Dean's List Semi-Finalist 2016
Unread 11-01-2017, 16:19
Matt_Boehm_329 Matt_Boehm_329 is offline
FRC #0329
Matt_Boehm_329 has a spectacular aura aboutMatt_Boehm_329 has a spectacular aura about
I think it is easier to do well with Tank, but there is more potential in Mecanum. I also feel that most of what Mecanum can do, Swerve can do better (except module complexity).
Unread 11-01-2017, 21:56
ns3517's Avatar
ns3517 ns3517 is offline
FRC #0316 (Lunatecs)
ns3517 will become famous soon enough
I would say tank because the cons of mecanum out weigh the benefits
Unread 11-01-2017, 22:21
sonichammer7476's Avatar
sonichammer7476 sonichammer7476 is offline
FRC #3959 (Morgan County Mech Tech)
Team Role: Scout
Rookie Year: 2014
sonichammer7476 has a spectacular aura aboutsonichammer7476 has a spectacular aura aboutsonichammer7476 has a spectacular aura about
It all depends on what strategy you are going to go for of course, but if you are going to play any defense or fight for balls in the neutral zone, I highly recommend tank over mecanum. 99% of the time, you will get tossed around like a rag doll when facing non-mecanum robots. No traction. But as one user suggested earlier, if you are very familiar with mecanum and not familiar at all with tank, or your driver is skilled enough to handle the challenges of mecanums in this game, then go with mecanum. Otherwise, I say tank.
Unread 12-01-2017, 14:01
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
As it looks like most people, I would recommend tank. Using the KoP, it is very simple to do and does't really take much thinking or programming to do. Mecanum from my understanding isn't overly complex but it takes more work. A downside to Mecanum is that it can't really hold it's ground that well, and you could be pushed a lot. A tank drive may not maneuver as sharp or nice but with the defense ability this year, I would highly not recommend mecanum, but that's for the strategy my team wants. My team did mecanum in 2015, but we also didn't have robot-to-robot contact.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 12-01-2017, 14:19
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think a small 6 wheel tank drive robot, in the hands of a well practiced driver, will be able to do amazing things.....
  #15   Spotlight this post!
Unread 11-01-2017, 12:00
niklas674's Avatar
niklas674 niklas674 is offline
Team 701 CAD Leader
FRC #0701 (Robovikes)
Team Role: CAD
Rookie Year: 2015
niklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of lightniklas674 is a glorious beacon of light
Tank.
My views do not represent the views of my team
