Go to Post So just stamp "GEEK" on my forehead - dlavery [more]
Unread 11-01-2017, 14:19
Team2909 Team2909 is online now
FRC #2909
Team2909 is an unknown quantity at this point
Exclamation What kind of encoders should I get?
We have a toughbox micro and 6 inch mechanum wheels. What type of encoders do we need.
Unread 11-01-2017, 16:44
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: What kind of encoders should I get?
Welcome to Chief Delphi !
http://youtu.be/LlSoEfAW47I?t=3m33s
Unread 11-01-2017, 16:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Incremental.
What are you trying to do? Theoretically you don't need encoders at all.
<Now accepting CAD requests and commissions>
Unread 12-01-2017, 10:03
FRC #2909
We would like to put encoders on for autonomous. Originally had tank tracks, but we are switching to mechanum. Figured it would be easier and more reliable to use encoders.
Unread 12-01-2017, 10:12
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Team Role: Leadership
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Quadrature encoders are the standard for drivetrains.
Andymark has USDigital E4T encoders, which work well with their gearboxes. I have had bad experiences with their connectors though. They also sell SRX magnetic encoders, which we got this season. They require additional machining, but seem better in most other ways. Many teams also use Grayhill shaft encoders (you can find them on Digikey), but you will have to find someone else to talk about these.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 12-01-2017, 10:14
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
I've had success with the amt encoders from FIRST Choice.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 12-01-2017, 10:29
Ether's Avatar
Rookie Year: 1969
We would like to put encoders on for autonomous. Originally had tank tracks, but we are switching to mechanum (FTFY). Figured it would be easier and more reliable to use encoders.
Following up on asid61's question: What are you trying to do?
e.g. Do you plan to use the encoders just to close the loop on wheel speed?
or are you going to try to use the 4 encoder velocity readings to compute vehicle speed and yaw rate?
or are you going to try to use the 4 encoder position readings to compute vehicle position and angle?
or something else?
Unread 12-01-2017, 11:45
BDRessler's Avatar
BDRessler BDRessler is offline
Programming Lead
FRC #1828 (BoxerBots)
BDRessler has a spectacular aura aboutBDRessler has a spectacular aura about
we have had success with these in the past, but be careful with mecanum wheels, as they tend to sacrifice accuracy with encoders due to slippage. This year, we are looking into using an optical mouse for our linear odometry and an imu for rotational.
