Go to Post I know the world needs more engineers, but FIRST isn't all about engineers and robots... that's why it's so great. - Ryan Dognaux [more]
Unread 11-01-2017, 15:14
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
SendableChooser changes and errors
It appears that SendableChooser is now a template based class. Is there any documentation on how to use it?
We made some changes to use it as:
Code:
SendableChooser<int> *pChoice;
pChoice = new SendableChooser<int>();
And once instantiated and objects are added, wanted to check it via:
Code:
int ch = pChoice->GetSelected();
or
Code:
int ch = (int)pChoice->GetSelected();
Both have been unsuccessful. Errors from compilation are:
Code:
arm-frc-linux-gnueabi-g++ -std=c++1y -I/Users/rwolff/wpilib/cpp/current/include -I/Users/rwolff/dev/robotics/FRCTeam1967/code/NatSndChTestJig/src -I/Users/rwolff/dev/robotics/FRCTeam1967/code/include -I/Users/rwolff/wpilib/user/cpp/include -O0 -g3 -Wall -c -fmessage-length=0 -o src/Robot.o ../src/Robot.cpp
In file included from /Users/rwolff/wpilib/cpp/current/include/SmartDashboard/SendableChooser.h:51:0,
                 from /Users/rwolff/wpilib/cpp/current/include/WPILib.h:72,
                 from ../src/Robot.cpp:1:
/Users/rwolff/wpilib/cpp/current/include/SmartDashboard/SendableChooser.inc: In instantiation of 'T frc::SendableChooser<T>::GetSelected() [with T = int]':
../src/Robot.cpp:38:42:   required from here
/Users/rwolff/wpilib/cpp/current/include/SmartDashboard/SendableChooser.inc:60:12: error: cannot convert 'std::nullptr_t' to 'int' in return
     return nullptr;
/Users/rwolff/wpilib/cpp/current/include/SmartDashboard/SendableChooser.inc: In member function 'T frc::SendableChooser<T>::GetSelected() [with T = int]':
I'm not sure if maybe it's only intended to be used with classes or class pointers and not something simple like an int possibly? Or if there's something more basic in err here.
Thanks!
roboBob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 11-01-2017, 17:02
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: SendableChooser changes and errors
http://wpilib.screenstepslive.com/s/...smartdashboard shows how to use it with an object. Personally, I think SendableChooser is overkill for basic types that are supported by SmartDashboard, and would just use the SmartDashboard methods.
Unread 11-01-2017, 17:09
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Code:
Code:
or
Code:
Code:
     return nullptr;
Thanks!
roboBob
nullptr is std::nullptr_t while you set the return type to int. Make it return the correct type. You can use specialized template functions
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-01-2017, 17:33
Da' Mentor Man
FRC #1967
Rookie Year: 2007
Joe - thanks for the pointer. I'll take a look at it working with an object instead of a int, but that seems a bug to me if it only works with objects. As for your statement about overkill ... this is being used for picking an autonomous 'mode' prior to match start ... how can you utilize SmartDashboard to do that? I don't see any way to choose from a list or a set of radio buttons or just buttons to do that.
Euhlmann - while I understand the error notes the different types, this is a template class now and as such, looking at the definition of GetSelected() shows that the type "T" of the template is used as the return type for that function. I templated it with <int> and yet the return of GetSelected() isn't returning that int.
roboBob
Unread 13-01-2017, 16:53
Da' Mentor Man
FRC #1967
Rookie Year: 2007
BTW, I did get a good clean compile by changing the template type from<int> to <int*>. Seems a deficiency of the template class to me, but it compiled at least.
