Go to Post Also, after 3 years of FRC I finally hugged that Platypi! - That 281 Guy [more]
Unread 11-01-2017, 19:30
MikePerreman's Avatar
MikePerreman MikePerreman is offline
FRC #0247
MikePerreman is an unknown quantity at this point
Exclamation Well, this is getting a bit old, but here is round 3
so, brand new laptop, i installed the update suite, cpp and java plugins, well, surprise surprise, the mdns doesn't work right, i can connect fine over usb and ethernet, if i set the roborio to a static 10.2.47.2, just put that in the ds, and dumping code seems to work ok. but i feel it more of a workaround, not a fix. i am running windows 10, and it would appear that, between windows and dell, its up to date. is there a mdns that im supposed to install as a worst case senerio, or what. this is the 3rd (unique) laptop that has this problem. what have i done wrong?
nevermind, dumping code doesnt work, it gets here:
get-target-ip:
[echo] Trying Target: roboRIO-247-FRC.local
Unknown host: roboRIO-247-FRC.local
[echo] roboRIO not found via mDNS, falling back to DNS
Unknown host: roboRIO-247-FRC.lan
[echo] roboRIO not found via DNS, falling back to static USB
[echo] roboRIO found via static USB
dependencies:
then stalls out, the bot is not connected via USB, only wireless
Programmer - A creature known for converting Caffeine into Code.
