Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
Unread 11-01-2017, 19:38
mlaga97 mlaga97 is offline
FRC #1421
mlaga97 is an unknown quantity at this point
Build of GearsBotDemo fails, but only for linux_simulate target
I have installed the frc toolchain, eclipse, frc plugins, and frcsim using the 2017 instructions on Ubuntu 16.04.
I loaded the example project GearsBotDemo in Eclipse and I am able to successfully build the project for the default target.
My issue is that when I attempt to build the linux_simulate target, the build fails at the linking stage with an error message consisting of several variants of the following:
./src/Subsystems/Claw.o: In function `Claw::Claw()':
/home/myusername/workspace/WPILib/GearsBot/linux_simulate/../src/Subsystems/Claw.cpp:6: undefined reference to `frc::Subsystem::Subsystem(std::__cxx11::basic_str ing<char, std::char_traits<char>, std::allocator<char> > const&)'
makefile:47: recipe for target 'FRCUserProgram' failed
./src/Subsystems/Claw.o:(.rodata._ZTV4Claw[_ZTV4Claw]+0x78): undefined reference to `frc::Subsystem::GetName[abi:cxx11]() const'
./src/Subsystems/Claw.o:(.rodata._ZTV4Claw[_ZTV4Claw]+0x90): undefined reference to `frc::Subsystem::GetSmartDashboardType[abi:cxx11]() const'
./src/Subsystems/Claw.o:(.rodata._ZTV4Claw[_ZTV4Claw]+0xa8): undefined reference to `non-virtual thunk to frc::Subsystem::InitTable(std::shared_ptr<ITable>) '
./src/Subsystems/Claw.o:(.rodata._ZTV4Claw[_ZTV4Claw]+0xb0): undefined reference to `non-virtual thunk to frc::Subsystem::GetTable() const'
./src/Subsystems/Claw.o:(.rodata._ZTV4Claw[_ZTV4Claw]+0xb8): undefined reference to `non-virtual thunk to frc::Subsystem::GetSmartDashboardType() const'
./src/Subsystems/Claw.o:(.rodata._ZTV4Claw[_ZTV4Claw]+0xc0): undefined reference to `non-virtual thunk to frc::Subsystem::GetName() const'
The only thing tying all of them together are that they are all members of the frc namespace.
Any help would be greatly appreciated.
Unread 12-01-2017, 13:08
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: Build of GearsBotDemo fails, but only for linux_simulate target
SNIP
I think that is an issue of GCC 5 being used by default on 16.04, whereas our build system uses 4.9 to build the libraries. Try adding the following line to to the top of every source file in your code, above any includes.
#define _GLIBCXX_USE_CXX11_ABI 0
I haven't tested that, but I have a hunch.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 12-01-2017, 14:59
FRC #1421
After those changes are made, the build then fails at the linking stage with the following error:
Code:
g++ -L/usr/lib/x86_64-linux-gnu -L/home/myusername/wpilib/simulation/lib -Wl,-rpath,/opt/GenICam_v3_0_NI/bin/Linux32_ARM -Xlinker -rpath /home/luc_lagarde/wpilib/simulation/lib -o "FRCUserProgram"  ./src/Subsystems/Claw.o ./src/Subsystems/DriveTrain.o ./src/Subsystems/Elevator.o ./src/Subsystems/Wrist.o  ./src/Commands/Autonomous.o ./src/Commands/CloseClaw.o ./src/Commands/DriveStraight.o ./src/Commands/OpenClaw.o ./src/Commands/Pickup.o ./src/Commands/Place.o ./src/Commands/PrepareToPickup.o ./src/Commands/SetDistanceToBox.o ./src/Commands/SetElevatorSetpoint.o ./src/Commands/SetWristSetpoint.o ./src/Commands/TankDriveWithJoystick.o  ./src/OI.o ./src/Robot.o   -lwpilibcSim -lgz_msgs -lntcore -lgazebo_client -lboost_system
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::transport::Publisher::Publisher(std::string const&, std::string const&, unsigned int, double)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::transport::Node::DecodeTopicName(std::string const&)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `google::protobuf::MessageLite::ParseFromString(std::string const&)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::transport::Node::Init(std::string const&)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::transport::ConnectionManager::Advertise(std::string const&, std::string const&)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `google::protobuf::internal::kEmptyString'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::transport::TopicManager::UpdatePublications(std::string const&, std::string const&)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::common::Exception::Exception(char const*, int, std::string)'
/home/myusername/wpilib/simulation/lib/libwpilibcSim.so: undefined reference to `gazebo::transport::TopicManager::FindPublication(std::string const&)'
Any ideas? I appreciate your help.
