Go to Post A quote from the Southern California Regional Visitors guide: "If you are having problems the FIRST thing to do is ask your neighbor for help" - ChrisH [more]
Unread 12-01-2017, 10:29
Sol.b.houston Sol.b.houston is offline
FRC #6183
Sol.b.houston is an unknown quantity at this point
Question How to find the dimensions for parts used in the team version of the field component?
We cant seem to be able to locate the dimensions for the parts used, length ect., any help is a appreciated!
Sol Houston
Team 6183
Unread 12-01-2017, 10:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: How to find the dimensions for parts used in the team version of the field compon
Is this something missing from the team versions document?
Each field element begins with the overall picture, then breaks down subassemblies to single components.
Unread 12-01-2017, 10:46
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
https://firstfrc.blob.core.windows.n...amVersions.pdf has drawings of the team field components.
Suppose you are building TE-17001, the Rope Climb. The bill of material in the lower right hand corner shows the components of this assembly. Let's go figure out how to make TE-17001-01, the Rope Climb Upright. The table tells us we need to make 2 of them.
Move to page 3 of the PDF file. At the top of the page, there's a diagram that shows how to make TE-17001-01, which is a 58.5" long section of 2x4 lumber.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 12-01-2017, 13:50
FRC #6183
Thumbs up Re: How to find the dimensions for parts used in the team version of the field compon
Hey guys sorry, the person who printed it out missed the dimensions sheet! thanks to all for replying!
