Go to Post Unlike robot design, in the clothing world there's no such thing as too much pocketing - Jaci [more]
Unread 12-01-2017, 14:13
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Realistic high goal scoring rate
Originally Posted by Kevin Sevcik View Post
I am in complete agreement with this, actually. The important shooter metric is balls scored per second, not accuracy or balls fired per second. Erring on the side of volume is almost certainly preferred because it's probably easier to increase accuracy for a high volume system than to increase volume for a high accuracy system. I think it IS interesting that if you're pursuing a single stream shooter*, at some point you have to start backing away from the goal to increase your rate of fire without running balls into each other.
*How long do you think until the first joke about crossing the streams?
Unread 12-01-2017, 14:28
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Originally Posted by notmattlythgoe View Post
Ghostbusters!
14:06-14:13, so ~7 minutes
Longer than I expected actually.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 12-01-2017, 14:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
He has to have some kind of intelligent filter that notifies him of joke opportunities, I swear.
Unread 12-01-2017, 14:48
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
That's the first time I've ever heard him referred to as "intelligent"
Unread 16-01-2017, 11:43
Flywheel Police
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Rookie Year: 2011
Andrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant future
97.1 balls per second.
Unread 12-01-2017, 15:11
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
next thing you know 254 does better than that
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2017, 16:03
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
So, check my math, but assuming a single Fuel leaving the shooter wheel which is located at the top of a tall robot parked in the key against the boiler wall. My trajectory model calculates about 86 degree launch angle at about 5.7 m/s muzzle velocity. At a 5" pitch, that is 40 to 45 Fuels per second.
So that would be the max; of course, there would be a gap as you wouldn't be feeding the shooter as fast, so something less than that.
Am I missing something?
Unread 12-01-2017, 19:20
Andrew_L's Avatar
AKA: Drübr Inc.
Rookie Year: 2011
I can't hear you over my ACTUAL TRANSFORMER ROBOT*
*Whose design I didn't contribute to in the slightest
Unread 12-01-2017, 19:58
Rookie Year: 1998
At 25 ft/s, that's about 12 lbs of thrust. I don't think you'll be going to space today with that engine.
Unread 13-01-2017, 00:19
AcidWombat AcidWombat is offline
FRC #0971
AcidWombat is an unknown quantity at this point
Nah. We'll just fix it in code
Unread 12-01-2017, 13:31
Drive Coach
AKA: Antoine L.
Rookie Year: 2012
Very cool! How to you plan on implementing that hopper in a 36" (or 24") tall robot
it seems possible for now to stay under 24", that would allow for a larger drive base, and a larger intake
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
We are looking at about 12 balls per second at the moment with our protoype with consistency.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 12-01-2017, 17:03
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Peak rate or sustained rate? I could see some team with peak rates well above 30 balls/second.
Flywheel shooters are the only way to launch a ball
Being correct doesn't mean you don't have to explain yourself.
  #15   Spotlight this post!
Unread 13-01-2017, 10:42
NathanStro's Avatar
NathanStro NathanStro is offline
Webmaster for 5980
AKA: Nathan Strodtbeck
FRC #5980 (East Grand Rapids Robotics)
Team Role: Webmaster
Rookie Year: 2016
NathanStro is an unknown quantity at this point
I would take a bet and say 3 balls a second will be the average scoring rate. Just a thought though.
Its not about the robot
