Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Unread 12-01-2017, 12:31
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Realistic high goal scoring rate
I keep seeing discussion about the high goal scoring rate required to maximize score. This is all well and good, but it's all theoretical. What do you think is a realistic rate of fire for a high goal shooter for an individual robot. An explanation of how you reach that number would be appreciated
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 12-01-2017, 12:33
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
Team Role: Mechanical
Rookie Year: 2011
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
Re: Realistic high goal scoring rate
I think realistically a well refined Ri3D 1.0 shooter could reach 3 balls/sec. And I believe there will be at least one powerhouse team with more than one shooter on their robot.
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 12-01-2017, 12:35
A-A-Ron (Sum)'s Avatar
A-A-Ron (Sum) A-A-Ron (Sum) is offline
AKA: Aaron Thompson
FRC #4961 (Shock and Awe-Sum)
Rookie Year: 2014
A-A-Ron (Sum) is an unknown quantity at this point
This is also the sentiment from my team. We are going into this season under the idea that great teams will have 2 or 3 shooters at around 3 fuel/second.
Unread 12-01-2017, 12:40
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
how about 12 fuel per second?
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2017, 12:48
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Originally Posted by MaGiC_PiKaChU View Post
Are you guys French?
My team was testing out our shooter yesterday and we were able to do at least 3 per second pretty accurately
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 12-01-2017, 12:49
Drive Coach
AKA: Antoine L.
Rookie Year: 2012
yes, sorry about that
Unread 12-01-2017, 12:51
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
No problem I was just surprised lol
Adam Spears
Unread 12-01-2017, 12:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Yes, but accuracy. At that distance you're going to need much tighter control of the ball velocity. And the closer you get, the lower your rate of fire has to be.
Unread 12-01-2017, 12:56
Drive Coach
AKA: Antoine L.
Rookie Year: 2012
we were shooting from that distance to see how the wheel slowed down. By adding mass to the flywheel and shooting from closer, accuracy will go up a lot
Unread 12-01-2017, 14:01
Rookie Year: 1998
I need to revisit my flywheel spinup spreadsheet and add a few new features to it. Think I'll do that tonight.
At any rate, if you're using an encoder to do closed loop control of your shooter speed, you want a specific gear ratio to maximize your rate of fire. You want a gear ratio that has the motor spinning at 1/2 its free speed when your wheel is at target speed, or something very close to this (err on the side of a bit more reduction). This puts the motor at its peak power point when its at firing speed, which will minimize the recovery time to target speed, or atleast minimize the speed drop when dumping an entire load of balls.
Interestingly, this is not the gear ratio that spins the motor up from zero to target speed the fastest. That depends on the system dynamics, but the example I'm working with has that ratio at 40% more reduction, and increases recovery time by 16%. Which would give you a rate of fire of 86% the theoretical max.
Unread 12-01-2017, 14:05
Chris is me's Avatar
AKA: Pinecone
I don't think that's how it works. The motor is only at max power spinning half its free speed at full voltage, IE if the load the motor is under is slowing it down that much. If you're just spinning the motor at half its free speed with speed control, you're just applying a bit more than 6 volts to the motor (a bit more to account for friction losses etc). You definitely do want to be spinning a flywheel at less than 100% speed so it has some headroom to recover with, but I don't think it's exactly half voltage or half free speed either.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Well, that depends on how many balls you can shoot at the same time...
Unread 12-01-2017, 13:14
Part of why I'm asking. You tell me
EDIT:
Very cool! How to you plan on implementing that hopper in a 36" (or 24") tall robot
Unread 12-01-2017, 13:22
AKA: Pinecone
I think top teams will get to a dozen per second, absolutely. Multiple ways to accomplish this shooting task this year - if the way you have in mind can't do it, think outside the box a little.
This isn't 2016 - volume and accuracy are tradeoffs where the right answer very well may be on the side of volume. Turreted shooter in 2009 could be more accurate than dumpers, but dumpers certainly were the more dominant design in general that year. This year's game has five times as many game pieces as 2009!
  #15   Spotlight this post!
Unread 12-01-2017, 14:06
Rookie Year: 1998
I am in complete agreement with this, actually. The important shooter metric is balls scored per second, not accuracy or balls fired per second. Erring on the side of volume is almost certainly preferred because it's probably easier to increase accuracy for a high volume system than to increase volume for a high accuracy system. I think it IS interesting that if you're pursuing a single stream shooter*, at some point you have to start backing away from the goal to increase your rate of fire without running balls into each other.
*How long do you think until the first joke about crossing the streams?
Like I said, I need to revisit my spreadsheet to better account for this. But two things are true about my statement:
1. If your wheel slows down by x% per ball, the fastest way to spin it back up to target speed is at at the peak mechanical power point. (Physics, that) And the peak power is at 12V and 50% free speed.
2. Peak power is the MOST power you'll ever get out of the motor. That's 337W for a single CIM. If it takes 33J to fire a ball, the most balls you can fire without slowing down is 10 balls per second. And that's going to be with the motor running at 1/2 free speed. If the motor's running any faster, it won't put enough energy back into the system and the wheel will slow until energy out = energy in.
