Go to Post If the GDC can actually top Rebound Rumble, I might cry at the reveal. - PayneTrain [more]
Unread 12-01-2017, 19:10
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Interesting Talon SRX Failure
Over the past two meetings we spent about four hours trying to diagnose a perplexing problem - our test base drive (6 CIM tank) would work fine in open-loop control, but half of it would not move in closed-loop control mode (even with a pure F loop, which is basically open-loop control).
As it turns out, the Talon SRX that was being used as the master for that side of the drive does not function in speed control mode, yet functions fine in percent vbus mode. We set it to be a slave and picked another talon as master, and the drive is now working. We'd send it back, but we're currently short on Talons.
Has anyone else had this failure mode? Any idea what could cause it, or if it's fixable?
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 12-01-2017, 19:14
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: Interesting Talon SRX Failure
Have you contacted ctre? They are very very very very very helpful.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 12-01-2017, 21:11
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
We try.
Whenever you run into an issue like this, please feel free to e-mail us - the address is "support" at our ctr-electronics.com domain. We try to monitor CD as much as we can, but e-mailing us is a much better way to get a quicker response.
At first glance, my initial suggestion for this problem is to check the firmware version of the Talon SRX you're having issues with, especially if it's a Talon SRX that hasn't been used before - the ship version of firmware can be very old.
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
