Go to Post Al Gore invented the internet...right? :p - coastertux [more]
Unread 13-01-2017, 12:04
GavinL GavinL is offline
intensely stares at program
FRC #5726 (RhumBotz)
Rookie Year: 2016
GavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to behold
Question Will this work?
To set the drive to tankdrive I put this in my DriveWithJoysticks command file, right?
(had to put spaces on oi because it would make the face)
void DriveWithJoysticks::Execute() {
Robot::driveTrain->robotDrive41->TankDrive(
Robot:: oi->getopStick()->GetRawAxis(1),
Robot:: oi->getopStick()->GetRawAxis(5));
OR
Should I just create an if statement that checks if getrawaxis(1) > deadZone, then set left motor outputs to 1.
Unread 13-01-2017, 13:43
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Will this work?
One of my pet peeves is a "binary" joystick. That is one where the sticks aren't balanced well enough and you can't really hold them part of the way (so it's always close to either 0 or 1). Equally annoying is when someone uses an xbox 360 or xbox one controller as if it were binary. Essentially gunning the robot, realizing it's going too fast, immediately stopping, then full speed again, and so on; speed control by manual switching (bad!). There's actually a reason you want to use complicated motor controllers (instead of spikes) and high quality joysticks: because you don't want to be going top speed all the time!
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 13-01-2017, 17:07
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: Will this work?
Gavin,
First ... feel free to use the "["CODE"]" and "["/CODE"]" markers (without the double-quotes) around anything that you want NOT formatted (smiles etc) - works like a champ.
Code:
int i=25;
Now for TankDrive, this is the drive mechanism where you (usually) want two joysticks - one is all about the left wheels and the other is all about the right wheels. Right? If that's indeed what you're looking for, then only the Y-Axis would be looked at for each of the joysticks. As such, TankDrive() would have inputs from two different sticks like:
BTW - I'm not familiar with your Robot:: class so I'm going to use my own 'Joystick' instances - if you have your own already, feel free to substitute...
Found somewhere like RobotInit()...
Code:
JoyStick leftStick(0);
JoyStick rightStick(1);
Code:
TankDrive(leftStick.GetY(), rightStick.GetY());
This is the gist of it. Does that make sense? Let me know if not.
roboBob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 14-01-2017, 02:50
Rookie Year: 2016
Re: Will this work?
Originally Posted by bob.wolff68 View Post
Gavin,
Code:
int i=25;
Code:
Code:
roboBob
Yes it makes sense. Its just that we are using a logitech f310 so I have to use one port. Also last year we had it set up with the if statement, worked pretty well. Just didn't know if we should keep doing that or go to the TankDrive().
Unread 14-01-2017, 04:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Will this work?
If you're going to stay with it, it doesn't make a lot of difference. If you think you might want to change driving mode (e.g. to arcade drive), then coding it as tank drive at this point would make a much easier transition.
