Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 13-01-2017, 12:59
Dave Hurt Dave Hurt is offline
Mostly Harmless
FRC #6413 (Degrees of Freedom)
Rookie Year: 1999
Dave Hurt is on a distinguished road
No robot code, but can start it manually
I've setup robotpy 2017.0.2 on my rio and pushed a very simple project to it. Deploy goes ok, but the dashboard says no robot code. So I ssh'd into the rio and started the code manually and then everything started working. Dug around a little bit and I can't find a cause for it, anyone have any thoughts? Thanks!
Unread 13-01-2017, 15:48
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
Re: No robot code, but can start it manually
I just took some code and pushed it to the roborio via usb, worked fine. Driver's station reports it perfectly. Don't know what to say bud.
Unread 13-01-2017, 16:28
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
The best way to check this would be to try using the --nc flag to the deploy command to see if there's any error messages that show up. You can also look at the console in the driver station to see if messages show up there (it'll show the same thing).
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 14-01-2017, 14:29
applesauce2011 applesauce2011 is offline
Rookie Year: 2016
applesauce2011 is an unknown quantity at this point
I'm working with Dave, these are the messages we see in in the Driver Station
env: can't execute '/usr/local/frc/bin/netconsole-host': No such file or directory
Warning 44002 Ping Results: link-bad, DS radio(.4)-bad, robot radio(.1)-bad, cRIO(.2)-bad, FMS-bad FRC: Driver Station ping status has changed. Driver Station
Unread 14-01-2017, 14:40
virtuald's Avatar
RobotPy Guy
Did you install using the manual instructions, or by using the installer?
In the RobotPy installation package, there's a directory called 'opkg_cache', and it should have two packages... Python and netconsole-host. If you don't install netconsole-host, you'll get that error. If you use the 'install-robotpy' installer command, it should already do that for you.
Feel free to get on the RobotPy gitter channel and I can assist in realtime.
Unread 14-01-2017, 15:05
virtuald's Avatar
RobotPy Guy
To follow up with others, they were installing last year's release of RobotPy, which is why netconsole-host wasn't being installed.
