Go to Post To ANY Robowrangler students reading this thread: If any of you ask me about the game hint, at any time, you will be assigned 4 hours of shop cleaning duty during week 1. No exceptions. - JVN [more]
Unread 13-01-2017, 15:20
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
Fuel Processing Question
Hello,
Does anyone know or have any clarification on the fuel processing speed?
To clarify, the manual says the boiler can process 5 fuel per second. Does this imply that if I fire more than 5 balls into the boiler per second they will stack up like sand in an hour glass waiting to be processed, or does this mean that anything over 5 balls per second will be wasted, I.E. not counted by the system.
Thanks!
Unread 13-01-2017, 15:27
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: Fuel Processing Question
Originally Posted by c.shu View Post
Hello,
Thanks!
They will stack up like sand in an hour glass but there is a capacity for how many balls the goal can hold
#StaySavage
Unread 13-01-2017, 15:28
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Which is about 70 for the low goal and about 150 for the high goal [3.11.4 Boiler].
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 13-01-2017, 16:06
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
I think the 5 /sec is if chamber is filled and 15/s is if its not filled there are many drop points (~16) to counter so it'll take ~8 to start to slow processing , I expect first balls to get counted at 15/sec then if starting to fall behing slowest is 5/ sec when counter saturated probably
So I envision a single stream is better than a 40-50 ball dump IMO, as with the stream you will maintain closer to 15 /sec processsing a bog dump as it WILL saturate the counter and be at 5 /sec and as it finishes the processsing exentually ramps up to 15.
Think of a garbage disposal.... several small chunks fast clear done drop chunks one at a time no significant slowdown , a boatlaod of junk is 3 times slower slow then fast as it processses. So the inital slowness has to clear slowing counting down.
So stream is faster than dump most likely in terms of processsing times ...im certain equivalent multiball stream will process faster than a massive dump in the chamber
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 13-01-2017, 22:16
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Where are you getting this information from? Or is it pure speculation at this point?
Unread 13-01-2017, 23:34
Rookie Year: 2014
Its speculation and insights from a 4yr original and only strategy.scouting mentor perspective. And basic what I call "common sense". Ever use a garbage disposal or gumball machine? I think its definitely my solid speculation (I endeavor to help the greater FRC community with my personal insight in this defined role I enjoy ) at this point . Its my role in strategy/scouting to evaluate all available information as to what's published or available and whats not and "fill in the blanks" to give our team the best info to compete effectively each season, sometimes I share my insights . The image of the counting mechanism is available publically I suggest you draw your own conclusions how processing would be impacted in a massive dump or a solid stream of Fuel . Otherwise I stand behind my analysis of such. I have been wrong occasionally so perhaps I'm off base . Up to you whether to use or not. Best of luck.
