You're so Vexy.
Unread 13-01-2017, 16:06
mentos54 mentos54 is offline
FRC #0247
mentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to behold
Rope and robot removal at end of game
I was planning on checking the Q&A for this, but since it's down, does anyone know if the rope can be attached to the robot when they are both removed from the field? My team is looking at a climbing design and are wondering if the rope would need to be able to be drawn out of the robot, or if we can have a purely one-way system.
Unread 13-01-2017, 16:10
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: Rope and robot removal at end of game
Blue box of R08
ROBOTS will not be re-enabled after the MATCH, so Teams must be sure that GAME PIECES and ROBOTS can be quickly, simply, and safely removed. Note that a Team provided ROPE may be removed from the FIELD and is no longer considered a FIELD element once removed from the DAVIT.
#StaySavage
Unread 13-01-2017, 16:23
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Originally Posted by JR0405 View Post
Blue box of R08
This. Bring your own rope and you can leave it attached to the robot, then remove it when you get back to your pit. Just make sure you'll be able to do so safely.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
