Go to Post Your GPA in High School and College is a reflection of your cooperation with educational processes, nothing more. It is NOT a measurement of how much you know or how much you can learn. - Mike Martus [more]
Unread 13-01-2017, 19:14
Kartoffee Kartoffee is offline
FRC #2834
Kartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to all
Velcro Usage
R05:
Traction devices must not have surface features such as metal, sandpaper, hard plastic studs,
cleats, hook-loop fasteners or similar attachments that could damage the ARENA. Traction
devices include all parts of the ROBOT that are designed to transmit any propulsive and/or
braking forces between the ROBOT and FIELD carpet.
This rule indicates that you aren't allowed to have Velcro (hook-and-loop tape) on your robot, but there are two points that might contradict that and I want a second opinion.
First, the term "...that could damage the ARENA". This means that if your traction device is unable to damage the Arena, such as loop-side Velcro (soft), then it should be allowed.
The other point is the last part, the definition of a traction device. "Traction
braking forces between the ROBOT and FIELD carpet". I would assume that a spool for climbing isn't considered something that is designed to transmit force with the field carpet.
Does this mean that the Velcro climbers are valid now?
Always blame the CAD team.
