Go to Post I feel like we should get karma points for "Inspiration via Q&A". - JVN [more]
Unread 13-01-2017, 19:29
WalnutsAndBolts WalnutsAndBolts is online now
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Exclamation FRC 2017 Joystick Control
Hello,
My team is a rookie this year, so we are still trying to figure things out, so sorry about this question if it is a simple answer.
My team would like to use the Logitech Joystick that is in our KOP. We are programming in LabView. Is there a way to connect this to our robot?
Thanks,
Walnuts and Bolts Robotics Team
Unread 13-01-2017, 20:35
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: FRC 2017 Joystick Control
The default LabVIEW robot project comes pre-programmed to use a single joystick like that one.
You need to:
  • Create a new project
  • Build the project
  • Run as Startup (to put it on the robot)
Plug the joystick in.
Go to the Setup tab in the Driver Station and make sure it shows up in the first slot (USB 0).
Unread 16-01-2017, 09:05
Omar's Avatar
Omar Omar is online now
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
The Joystick connects to your PC or Laptop, not your robot.
Omar
