Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
Unread 14-01-2017, 11:43
Blasting's Avatar
Blasting Blasting is offline
"That Guy"
FRC #1225 (Gorillas)
Rookie Year: 2015
Blasting is an unknown quantity at this point
GRIP Generated code
Our team (1225 Gorillas) is new to vision tracking this year. When I imported code generated by GRIP (C++) I get errors from missing #includes (<opencv2/contrib/contrib.hpp>, and "VisionPipeline.h") as well as "expected class-name before '{' token" at "class GripPipeline: public VisionPipeline {". Any ideas? I've updated, used a fresh chroot, messing with formatting, and our Windows machine. I'm running Ubuntu Xenial.
Unread 14-01-2017, 11:57
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: GRIP Generated code
If you're generating code and selecting "Implement WPILib VisionPipeline", you need to be generating the code into an Eclipse robot project. So the save directory would be something like ~/workspace/robot2017/src/
WPILib
GRIP, RobotBuilder
Unread 15-01-2017, 12:03
Blasting's Avatar
"That Guy"
Rookie Year: 2015
Thanks Sam, I still needed to edit some of the generated code so it would build but we're up and running now!
Unread 15-01-2017, 12:21
AKA: Sam Carlberg
What code did you have to change?
WPILib
GRIP, RobotBuilder
Unread 16-01-2017, 10:00
Blasting's Avatar
"That Guy"
Rookie Year: 2015
I remove the inclusion of <opencv/contrib/contrib.hpp> because there is no opencv/contrib folder.
I changed the inclusion of "VisionPipeline" to "vision/VisionRunner.h" to fix "Symbol 'VisionPipeline' could not be resolved GripPipeline.h line 25"
I commented out the setsource0() function, this solved various issues and doesn't appear to make any.
Lastly I had to add cv:: to a SimpleBlobDetecter::create() call near the end of GripPipeline.cpp.
If you need any logs, the generated and modified files, or any version numbers just ask.
Unread 16-01-2017, 12:31
tkdberger's Avatar
tkdberger tkdberger is offline
SPAAACE
AKA: Edwan Vi
FRC #3494 (Quadrangles)
Rookie Year: 2016
tkdberger is an unknown quantity at this point
Question Re: GRIP Generated code
How and where are you calling your pipeline? I've been screaming at my vision code for a while now.
