Go to Post You will find the LRI, Head Ref, & FTA don't have a lot of time for popcorn during a competition. :) - FrankJ [more]
Unread 14-01-2017, 11:55
WalnutsAndBolts WalnutsAndBolts is offline
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Exclamation LabView 2017
Hi,
I have downloaded the Labviewfile, but it does not open a setup wizard. How do I install it and run it?
Unread 14-01-2017, 15:14
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: LabView 2017
There are two LabVIEW installs you need:
1) the basic LabVIEW - this also comes on a DVD in your KOP (only if you are programming in LabVIEW)
2) The FRC specific Update
Download the files.
Unzip the files.
Click on Setup inside each folder.
Unread 17-01-2017, 00:26
Hess1113's Avatar
Hess1113 Hess1113 is online now
AKA: Christopher Hess
FRC #0291 (CIA)
Rookie Year: 2017
Hess1113 is an unknown quantity at this point
Smile Re: LabView 2017
Hello WalnutsAndBolts in the KOP there was a CD but if you use the internet browser verizon you still need the package the CD came with in your KOP because that has your serial number for labview. Here are directions
1.Download NI LabVIEW 2017 http://www.ni.com/download/labview-f...-17.0/6489/en/
2.After downloading and using the installer which should be automatic you should have LabVIEW 2016 (NI Gives use last years LabVIEW)
3.Download the update suite http://www.ni.com/download/first-rob...e-2017/6492/en
4.After downloading and using the installer you should have LabVIEW FRC 2017 and the options for the Driver Station and NI stuff.
If you are having issues getting the setup wizard to start find the file location and open file autorun.exe in the LabVIEW file installer file location.
Hope that helps. Happy Building
Unread 17-01-2017, 09:25
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: LabView 2017
One more good thing to know is if you go into the tab on the left that says "Support" and then click "Find FRC Examples..." in the center column, you will find implementable code that is already written for you to help you program.
