Go to Post Get your team together. Get your priorities straight. Get busy having fun. See you on the field. - EricH [more]
Unread 14-01-2017, 13:06
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Lenght of usable rope from scoring plate to end.
We know the rope must be 5'3" to 8' from the retaining knot to the end. So the question is what is the distance from the davit retaining feature to the point the robot scores the climb. I assume less than 29" since no knots can be in this zone. I haven't been able deduct the range the end of the rope can be presented for the robot to gather or into the climb subsystem.
Unread 14-01-2017, 22:46
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Rookie Year: 1999
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Re: Lenght of usable rope from scoring plate to end.
Bumping this... same question.
Length from davit retaining feature to the pressure plate (which is 4'10" from floor).
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 14-01-2017, 23:10
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
I was curious about the same thing, so I looked through the field component drawings.
On page 74, I found GE-17081 Upper Arm, which is the component of the DAVIT that we are interested in. Its ordinate dimensions indicate that the back of the fingers, where the knot will be stopped, is 3.25" from the edge at which the rope bends 90 degrees down. Vertically, that edge is 18.19" from the lowest point of the Upper Arm. So we will need 21.44" of rope between the knot and that point.
Looking at Fig. 3-19 on page 27 of the Manual, it appears to me that the TOUCHPAD assembly is mounted with its lower surface flush to the lowest point on the Upper Arm, but I cannot find a drawing that clearly indicates this.
Rule I04-F required that the top knot be at least 29" from the retaining knot.
So my best guess is that the highest knot that a robot could touch while climbing a legal rope will be 29 - 21.44 = 7.56" below the TOUCHPAD.
Someone please check this and correct me.
Richard Wallace
since 2003
Unread 14-01-2017, 23:33
Engineer/Mentor
AKA: Scott5736
Rookie Year: 1999
Thanks, that seems pretty good, but would be great to get a confirmation of the one assumption to be 100% (if anyone has info we do not).
If we use 7.5" from touch pad to top of a knot (29" from retaining knot), top of that knot would be 4' 2.5" from floor. That correct?
Unread 14-01-2017, 23:19
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Approximately 20" estimated from these photos if they help visualize it at all:
- http://www.team358.org/history/2017/...f/P1090710.jpg
- http://www.team358.org/history/2017/...f/P1090713.jpg
- http://www.team358.org/history/2017/...f/P1090725.jpg
You can see how the field rope knot will engage.
Note that the C-channel the rope lies in extends to the base of the touchpad and that the touchpad when pressed leaves the channel for the robot to possibly contend with if your hoist is at the tippy top of your robot.
Unread 14-01-2017, 23:26
Rookie Year: 1996
Thanks, Mark! Pictures really help. I wish my team were closer to a kickoff that has a real field.
Richard Wallace
since 2003
Unread 14-01-2017, 23:41
Engineer/Mentor
AKA: Scott5736
Rookie Year: 1999
Hey Mark, long time, no see (what, about 12 hours!).
Thanks for pics. Confirms the location, and brings up the issue of the c-channel. Appears as though it could block depression of the plate by a simple winch if the winch is highest point.
That is very interesting (and troubling at the moment!).
