libNiFpgaLv.so has wrong SONAME in ELF header?
I'm currently trying to get Google Test to work with a WPILib project so we can have tests integrated smoothly into our codebase (the rationale here could be a thread of its own, so let's not get into it). I've managed to get an executable compiled and linked, but I've been struggling to get the loader to cooperate. My procedure thus far:
1. Install qemu-user, the current FRC C++ toolchain, Eclipse, and the WPILib plugin on an Ubuntu machine. 2. Create a build configuration in Eclipse which links with both WPILib and gtest, with the test executable as the build artifact. 3. Build the executable. 4. Consolidate all relevant shared object files in one directory so that qemu's loader can find them. 5. Set up symlinks for the libraries that came with WPILib (the symlinks between different versions of libraries, e.g. libi2c.so -> libi2c.so.2, were created as regular files by the Eclipse plugin installer, so I wrote a script to remake them). 5. Run the executable using qemu-arm with a sufficiently large kernel version number and the loader path set to the directory containing the consolidated shared object files. On the last step, qemu throws an error which reads, "src/eclipse/2017Steamworks/test/Test: error while loading shared libraries: libNiFpgaLv.so.13: cannot open shared object file: No such file or directory". I found it strange that it was trying to load that version of the library, as the one that WPILib comes with is 16.0.0, not 13. However, when I checked the ELF header of the library, I found that the SONAME doesn't match the filename: Code:
$ readelf -d libNiFpgaLv.so.16.0.0 Dynamic section at offset 0xc3a0 contains 30 entries: Tag Type Name/Value 0x00000001 (NEEDED) Shared library: [libNiFpga.so.13] 0x00000001 (NEEDED) Shared library: [libstdc++.so.6] 0x00000001 (NEEDED) Shared library: [librt.so.1] 0x00000001 (NEEDED) Shared library: [libgcc_s.so.1] 0x00000001 (NEEDED) Shared library: [libpthread.so.0] 0x00000001 (NEEDED) Shared library: [libc.so.6] 0x0000000e (SONAME) Library soname: [libNiFpgaLv.so.13] Last edited by Thomas DeSilva : 15-01-2017 at 00:52. |
Re: libNiFpgaLv.so has wrong SONAME in ELF header?
If you look in /usr/local/natinst/lib/ on the roboRIO, you'll find symlinks from the foo.13 versions to the foo.16.0.0 versions (e.g. libNiFpga.so.13 is symlinked to libNiFpga.so.16.0.0).
Great, thanks. I'll have to poke around its file system on Monday and see if I can get this working.
It doesn't matter what the file name is, the runtime linker is going to want the library that the executable was built with that is embedded in the executable that calls itself libxxx.13.so by the name inbedded in the library file.
The name in the executable can be found with ldd or readelf. |
I moved all the libraries from the RoboRIO into my library search path, which solved the issue in my original post. However, now I have a different problem:
Code:
symbol lookup error: /lib/libHALAthena.so: undefined symbol: _ZN5nFPGA16nFRC_2017_17_0_220g_currentTargetClassE Code:
$ readelf -dW /usr/arm-frc-linux-gnueabi/lib/libHALAthena.so Dynamic section at offset 0x42434 contains 37 entries: Tag Type Name/Value 0x00000001 (NEEDED) Shared library: [libFRC_NetworkCommunication.so.17] 0x00000001 (NEEDED) Shared library: [libi2c.so.2] 0x00000001 (NEEDED) Shared library: [libRoboRIO_FRC_ChipObject.so.17] 0x00000001 (NEEDED) Shared library: [libspi.so.1] 0x00000001 (NEEDED) Shared library: [libvisa.so] 0x00000001 (NEEDED) Shared library: [libpthread.so.0] 0x00000001 (NEEDED) Shared library: [librt.so.1] 0x00000001 (NEEDED) Shared library: [libMathParser_gcc-4.4-arm_v3_0_NI.so] 0x00000001 (NEEDED) Shared library: [libwpiutil.so] 0x00000001 (NEEDED) Shared library: [libstdc++.so.6] 0x00000001 (NEEDED) Shared library: [libm.so.6] 0x00000001 (NEEDED) Shared library: [libgcc_s.so.1] 0x00000001 (NEEDED) Shared library: [libc.so.6] 0x0000000e (SONAME) Library soname: [libHALAthena.so] Code:
$ readelf -sW wpilib/cpp/current/lib/libFRC_NetworkCommunication.so.17.0.0 | grep FPGA
37: 00066948 41 OBJECT WEAK DEFAULT 12 _ZTS38NetCommRPC_getFPGAHardwareVersion_args
45: 00067198 42 OBJECT WEAK DEFAULT 12 _ZTS39NetCommRPC_getFPGAHardwareVersion_pargs
48: 0007ce80 8 OBJECT WEAK DEFAULT 18 _ZTI40NetCommRPC_getFPGAHardwareVersion_result
233: 0006716c 44 OBJECT WEAK DEFAULT 12 _ZTS41NetCommRPC_getFPGAHardwareVersion_presult
314: 0007ce68 8 OBJECT WEAK DEFAULT 18 _ZTI38NetCommRPC_getFPGAHardwareVersion_args
317: 00066974 43 OBJECT WEAK DEFAULT 12 _ZTS40NetCommRPC_getFPGAHardwareVersion_result
339: 0000d098 32 FUNC GLOBAL DEFAULT 10 getFPGAHardwareVersion
432: 0007d348 8 OBJECT WEAK DEFAULT 18 _ZTI39NetCommRPC_getFPGAHardwareVersion_pargs
440: 0007c240 8 OBJECT WEAK DEFAULT 18 _ZTI11FPGAVersion
449: 000657f0 14 OBJECT WEAK DEFAULT 12 _ZTS11FPGAVersion
537: 0007d330 8 OBJECT WEAK DEFAULT 18 _ZTI41NetCommRPC_getFPGAHardwareVersion_presult
$ readelf -sW wpilib/cpp/current/lib/libFRC_NetworkCommunicationLV.so.17.0.0 | grep FPGA
3: 00000000 0 OBJECT GLOBAL DEFAULT UND _ZN5nFPGA16nFRC_2017_17_0_220g_currentTargetClassE
