Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 15-01-2017, 15:29
godkane godkane is offline
FRC #3875
godkane is an unknown quantity at this point
RPLIDAR with java
I'm having issues getting the RPLILDAR v2 working with the default serial driver in java with the RoboRIO. I have no issues communicating when connected to a PC with my own C# code or provided C libraries.
Here is the webpage with the lidar including SDK documentation and code:
http://www.robotshop.com/en/rplidar-...r-scanner.html
Here is a simple command to have the LIDAR spin.
SerialPort sp = new SerialPort(115200, SerialPort.Port.kUSB1, 8, Parity.kNone);
byte[] b = new byte[5];
b[0] = (byte)0xa5;
b[1] = (byte)0xf0;
b[2] = (byte)0x90;
b[3] = (byte)0x01;
b[4] = (byte)0xc5;
sp.write(b, b.length);
sp.flush();
I do seem to be able to get basic health commands to work, just the more advanced commands such as spin and get reading do not work.
I have also connected V5 power to the power connector on the RPLidar board.
Any help would be appreciated.
Unread 30-01-2017, 05:07
thecitrozz thecitrozz is offline
None #0001
thecitrozz is an unknown quantity at this point
Re: RPLIDAR with java
I found the same problem with my new RPLidar v2.
Using the C++ example from the SDK, I found out that it's necessary to start the motor before sending the scan command.
Based on the Java implementation found in https://github.com/lessthanoptimal/j...eption/rplidar
I added
* Sends a command with data payload
protected void sendPayLoad(byte command, byte[] payLoad) {
if (verbose) {
System.out.printf("Sending command 0x%02x\n", command & 0xFF);
dataOut[0] = SYNC_BYTE0;
dataOut[1] = command;
//add payLoad and calculate checksum
dataOut[2] = (byte) payLoad.length;
int checksum = 0 ^ dataOut[0] ^ dataOut[1] ^ (dataOut[2] & 0xFF);
for(int i=0; i<payLoad.length; i++){
dataOut[3 + i] = payLoad[i];
checksum ^= dataOut[3 + i];
//add checksum - now total length is 3 + payLoad.length + 1
dataOut[3 + payLoad.length] = (byte) checksum;
try {
out.write(dataOut, 0, 3 + payLoad.length + 1);
out.flush();
} catch (IOException e) {
e.printStackTrace();
* Sends a command with data payload - int
protected void sendPayLoad(byte command, int payLoadInt) {
byte[] payLoad = new byte[2];
//load payload little Endian
payLoad[0] = (byte) payLoadInt;
payLoad[1] = (byte) (payLoadInt >> 8);
sendPayLoad(command, payLoad);
* Sends a start motor command
public void sendStartMotor(int speed) {
sendPayLoad(START_MOTOR, speed);
In order to start scan, simply invoke
driver.sendStartMotor(660);
driver.sendScan(500);
Just created a pull request on the Java implementation above.
bye
Francesco
Unread 30-01-2017, 06:18
scaryone's Avatar
scaryone scaryone is online now
FRC #0058 (The Riot Crew)
Team Role: Coach
Rookie Year: 2007
scaryone will become famous soon enough
I assume you are not using this on an FRC bot? It's listed over the $400 limit. Or does the volume discount price count?
Unread 30-01-2017, 08:14
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
About that...
https://www.chiefdelphi.com/forums/s...d.php?t=154127
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 30-01-2017, 12:00
scaryone's Avatar
Team Role: Coach
Rookie Year: 2007
oooo interesting. Thanks Marshall
