Go to Post Brains and hard work aren't necessarily about age or grade. - Redhead Jokes [more]
Unread 15-01-2017, 15:32
MuskieProgramme MuskieProgramme is online now
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Using RobotBuilder
I've been trying to get started with RobotBuilder (exporting to Java), but every time I try there are missing import statements and arguments. It's been very frustrating and I'm wondering if I should just stick to manually writing code myself. I can run through the project and correct the errors, but I'm very concerned about trying to explain this process to any other member of our team (ei those with little to no programming experience). RobotBuilder looks like a great tool, but I'd like it to generate runnable code.
Unread 15-01-2017, 18:57
ecpullen ecpullen is offline
Team 2648
FRC #2648 (Infinite Loop)
Rookie Year: 2014
ecpullen is an unknown quantity at this point
After exporting to eclipse you can go to the classes with errors and click ctrl shift o and it will automatically import.
Sent from my SM-G935R4 using Tapatalk
Unread 15-01-2017, 22:34
SamCarlberg's Avatar
SamCarlberg SamCarlberg is online now
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Using RobotBuilder
What classes aren't generating correctly? Subsystems, PID subsystems, ... ?
WPILib
GRIP, RobotBuilder
Unread 16-01-2017, 08:50
FRC #6420
Rookie Year: 2014
As I said before, I already fixed the imports, it's just irritating.
Robot.java was the only class with an error other than missing imports, it was trying to create a new DriveBase with no arguments (ei not passing any motors). I think this is because I named a subsystem DriveBase. I've since corrected it. I'll be testing the code on the robot later to day and let you know if any other errors are discovered.
Unread 17-01-2017, 14:07
Mikey Richards's Avatar
Mikey Richards Mikey Richards is offline
FRC #3812 (Bits and Bots)
Rookie Year: 2015
Mikey Richards is an unknown quantity at this point
My team started with RobotBuilder last year, and it was a struggle at first. RobotBuilder can't edit the imports because the imports can't be in its auto-generated code blocks. You will have to import them yourself. As for writing the code yourself, both options have their advantages. You can keep your stuff more orderly if you write it yourself, but it's going to take longer.
I know from experience. I've been trying to argue to program in pure Java. I still write my own code in Java. The other programmer writes in robot builder. We cooperate, and we use the one that works best.
Unread 18-01-2017, 13:17
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
Team Role: Leadership
Rookie Year: 2011
david.e.boles is on a distinguished road
If there's something actually buggy you should probably submit an issue here. Also, +1 for just using Java; we spent the first week of the season training people so that we could do that better.
