Go to Post After all, bitterness takes all the fun out of wiring. - Venkatesh [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 16-01-2017, 11:55
jjb.bailey jjb.bailey is offline
FRC #2404
Team Role: Parent
Rookie Year: 2015
jjb.bailey is an unknown quantity at this point
Encoder output wiring
Where and how are the encoders' channels A and B outputs wired to the RoboRIO? There are only loose wires, so not even a plug to give us a clue.
This year, we sort of a rookie group with respect to encoders and the RoboRIO. We've pored over the documentation, but we can't find the information.
Jona Bailey, Parent-Mentor
TNT2404, Pasadena, CA
Unread 16-01-2017, 12:27
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #2898 (The Flying Hedgehogs), FRC #1510 (Wildcats)
Rookie Year: 2012
Philip Arola is an unknown quantity at this point
Re: Encoder output wiring
You will have to either crimp them into plugs manually, or solder them onto wires already crimped in plugs. PWM plugs are compatible.
I found this diagram from a previous thread, and it is a good illustration of what it needs to look like.
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
