Am I sending you the right signals?
Unread 16-01-2017, 14:04
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Robust way to rotate an 18 inch square plate 90 degrees.
In general, what would be the most robust way to internally rotate a plate from horizontal to vertical (hinged on the bottom) that when in a vertical orientation is 18"(h) x 18"(w) x 3"(d).
We have researched cams, linkages, pulleys, acme screws, etc and are wondering what you think the most robust method of rotating a plate would be with very limited resources and no machining capabilities.
Thank you, so much for your time.
