Go to Post It's a bird! It's a plane! It's SUPER-TUBE! - dlavery [more]
Unread 16-01-2017, 14:34
DiscipleOfDean's Avatar
DiscipleOfDean DiscipleOfDean is offline
AKA: Ben
FRC #2526 (Crimson Robotics)
Team Role: Student
Rookie Year: 2015
DiscipleOfDean is an unknown quantity at this point
Turret Mechanism
Hello, I am from Team 2526 and we are trying to make a turret for this year's challenge, but we are having some difficulty making the rotating mechanism. We are thinking of using a lazy susan style rotating mechanism but are not sure if this is the best way to go. Does anyone have any experience building one of these mechanisms?
Unread 16-01-2017, 14:40
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
Re: Turret Mechanism
Take a close look at team 254's robot from last year, Dropshot. They had exactly what you're talking about, just a bit fancier.
Unread 16-01-2017, 15:03
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Team Role: Leadership
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
There are a couple options:
Andymark turret: Probably a bit too big for the fuel this year (unless you're doing a double shooter lol)
Use a belt wrapped around some type of tube with a pulley as the pinion
-399 did this in 2012
- You would need an outer circle dimension for this.
- You could probably find this dimension for the HTD belts that AM and VEX sell if you look hard enough
-Another option would be to use McMaster belts/pulleys (could possibly interface pulley on to a cim output versaplanetary)
-This method is like making a turret gear without actually making it. Could be something to look at if you don't have good machining capabilities.
Gears
- Custom cut if you have waterjet access ( inventor has a tool for auto-generating gears)
- make sure any pinion gear you use is compatible with the turret gear (standard FRC sizes 20 dp with 14.5 degree pa or 32 dp with 20 degree pa)
- Would probably be easier to interface with current FRC COTS components
- As mentioned above take a good look at 254s 2016 robot. Also look at TBA design hub for 2012 robots with turrets. 1114 2012 is also a good robot to look at (cad here).
to actually mount these on to your robot look at some of turntables found here: https://www.mcmaster.com/#lazy-susan-bearings/=15xunfe
edit: you can find outer circle in mm for 5mm pitch htd belts here
Unread 16-01-2017, 15:12
FRC #5929
My concern with any turret this year is the size. I've yet to find a good way to have a turret that didn't kill your carrying capacity so badly it made it nearly impossible to be worth while. just my 2c.
Unread 16-01-2017, 15:13
Chris is me's Avatar
AKA: Pinecone
When experimenting with a turret, be sure to test to see if the direction of the turret relative to the loading mechanism affects the accuracy of the shot. This may be an issue depending on your design.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Unread 16-01-2017, 16:07
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
2643 had just this problem in 2012 "Rebound Rumble." We used tubing as a conveyor system feeding a shooter mounted on a lazy Susan - shooting characteristics varied as the turret rotated.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
