#31
Re: Best Stopper Knots for Team Supplied Knots
Thanks so much for posting this picture. I had not seen the clevis pin before now. I wonder if someone could ask in the Q&A if teams are allowed to attach to the pin itself with a loop, and not rely on a stopper knot. That'd be far more secure for smaller diameters of ropes and straps of webbing. |
#32
Q142 has been Answered now.
#35
Edit - it could go just around one finger for the load, and the other to keep the knot rotated between the fingers. Not too bad. Last edited by GeeTwo : 19-01-2017 at 09:53. |
#36
Does anyone have a picture of the davit fingers? I saw a couple pictures from the unveiling of the game, but they weren't from a great angle.
#37
Oh man the Rock climber in me is cringing about some of the stuff I just read in this thread but there is some very good stuff in here.
A few points: 1, I saw spectra and Dyneema/ Vectra mentioned ( all just different names for uhmw-pe) Tying knots in these are very difficult and not recommended in the least as they dont hold knots. In climbing situations if you use these materials they are sewn together or if they do have knots you MUST have very long tails as they can capsize. ( There are other issues with these materials that I would love to talk about if your interested) 2, As for knot strength, the breaking strength of a knot is a function of the strength of the rope and the number and angle of the bend entering the knot, if you tie a knot and test to failure the cord almost always breaks at the knot. To this end the Figure 8 is the strongest knot you can use as it preserves the most amount of strength in the rope. If that is your concern this is your knot. 3. A very simple stopper knot widely used is the Barrel knot. Used widely to finish off rappel ropes to save climbers from rappelling off the ends of their ropes. Its very simple easy to tie and untie and expands the diameter of your knot. This knot will be limited by the size cord you choose to use. 4. When tying different ropes together very few methods beat a double fishermen in terms of strength but this works best with cord of a circular cross section. If using webbing you will want to use a water knot. |
#38
Cothron sounds like we are on the same page!
A figure 8 used as a stopper with regard to the davit would probably not be the best choice unless your cord was really thick. I was mentioning that more in regards to some earlier comments on the strengths of knots. The one I was referring to as a barrel knot is a knot of this type ![]() This would not be ideal for teams looking at very small diameter cords but if your in the 8mm-12mm rang it could do the trick. |
#40
As a sailor knots are pretty much second nature. When looking at 'popular' knots folks need to understand that strength is usually not the only concern. In many cases knots like the bowline are used because it's possible to untie one even after it's spent a year or two exposed to the elements under load.
All that said, I haven't seen anyone talking about how to tie a suitable stopper knot in webbing or cargo strapping that a lot of teams are planning on using. Ideas? Last edited by Tom Line : 19-01-2017 at 20:22. |
#41
I have very little sailing experience. In the 1980s, I did a lot of rock climbing as a trip leader with the outdoor rec group at Georgia Tech. Climbers work with dynamic kernmantel ropes, and webbing.
On the recommendation of a very experienced sailor, our team is now practicing climbing on Sta-Set, a popular double braid polyester cord that is used for several purposes on many boats. 3/8" diameter is rated 5100 lbf tensile. The price is not bad. Any comments or concerns, Tom? |
#42
Trophy braid is usually considered the softest and will probably be the easiest for velcro to grab if you're just using straight rope: http://www.apsltd.com/samson-ropes-t...raid-line.html Generally we use these as stopper knots because they form a large knot, but even after being under tension they can be easily undone. http://www.animatedknots.com/doubleo...om#ScrollPoint There isn't really much mystery in rope. |
#44
A busy week and couple of days away from the robot, and responses from climbers and sailers, and I lost context of the discussion.
I'd still be hesitant to use a stopper knot with 3/8" line on a opening that size. A loop around the fingers as described above would be a safer option. |
