Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 17-01-2017, 02:31
Noam Noam is offline
None #3034 (galileo)
Rookie Year: 2015
Noam is an unknown quantity at this point
help with installing robotpy
hello, I'm trying to install robotpy, but it doesn't work.. I downloaded the zip file, and I run this command
Code:
python installer.py install-robotpy
but I get this error
Code:
C:\robotpty1\1\1\robotpy-2017.0.4>
C:\robotpty1\1\robotpy-2017.0.4>python installer.py install-robotpy
Copying over the opkg cache...
Looking up hostname roborio-3034-frc.local ...
Connecting to robot via SSH at roborio-3034-frc.local
Copying over the pip cache...
Running installation...
Done.
python36 - 3.6.0-r1
python36 already installed, continuing...
Installing netconsole-host (1.0) on root.
Collected errors:
 * check_data_file_clashes: Package netconsole-host wants to install file /usr/local/frc/bin/netconsole-host
        But that file is already provided by package  * netconsole-launcher
 * opkg_install_cmd: Cannot install package netconsole-host.
Command '['C:\\robotpty1\\1\\1\\robotpy-2017.0.4\\win32\\plink.exe', '-pw', '', 'admin@roborio-3034-frc.local', 'bash opkg_cache/install_opkg.sh && /usr/local/bin/pip3 install --no-index --find-links=pip_cache --pre --upgrade wpilib robotpy-hal-base robotpy-hal-roborio robotpy-wpilib-utilities']' returned non-zero exit status 255.
(thats the only command that I tried)
how can I fix that ?
Thanks in advance
