Go to Post Too many hours of robotics and too little sleep causes me to forget things.... - AdamHeard [more]
Unread 17-01-2017, 10:03
WalnutsAndBolts WalnutsAndBolts is offline
FRC #6643 (Walnuts and Bolts)
Rookie Year: 2017
WalnutsAndBolts is an unknown quantity at this point
Exclamation Radio Configuration
My team is trying to setup our radio. We have downloaded the configuration software. The error says:
Bridge configuration failed: Failed to change IP Address, please check for an adapter with the address: 192.168.1.51. Please ensure the bridge is connected to this computer and try again.
How do we correctly configure our radio?
Unread 17-01-2017, 10:35
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
Team Role: Coach
Rookie Year: 2012
vScourge is on a distinguished road
Re: Radio Configuration
Did you fully disable the wireless adapter on that PC? Turning wifi off via hard button on a laptop is often not enough, you need to go into network settings in Windows, right-click the wireless adapter and hit "Disable".
That cleared this error up for me, then the configuration utility worked.
Unread 17-01-2017, 11:13
CurlyFries CurlyFries is offline
AKA: Troy Martin
FRC #2512 (Duluth East Daredevils)
Rookie Year: 2014
CurlyFries is an unknown quantity at this point
Also make sure that the ethernet cable is plugged into the right port. The configuration utility should have a diagram highlighting the correct port.
Unread 20-01-2017, 10:35
Team4656 Team4656 is offline
FRC #4656
Team4656 is an unknown quantity at this point
Our radio wont accept the bridge. It says the bridge firmware load failed. What should i do?
