Go to Post The more you cling to the misfortunes that have already befallen you, the less you'll be able move forward from here. - Kevin Sevcik [more]
Unread 17-01-2017, 12:23
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
navX-MXP/navX-Micro update for USB
Kauai Labs has been working with FIRST and National Instruments on an issue discovered when using USB Serial devices on the RoboRIO.
Updated FRC RoboRIO LabVIEW, C++ and Java Libraries containing a workaround for this issue are now available.
I'm using USB to communicate with navX-Micro or navX-MXP to the RoboRIO. What do I need to do?
  • C++, Java, LabVIEW: If your RoboRIO software communicates with navX-Micro or navX-MXP over USB, please update your libraries to version 3.0.316 or higher.
  • LabVIEW: the method for zeroing the yaw has changed slightly: the Zero Yaw VI now requires a Boolean input which is set to TRUE to initiate Zeroing the yaw.
Please see the Version 3.0.316 Release Notes for more details.
