Go to Post What happens on your team is not everyone's business!!!! - Bruneau1727 [more]
Unread 17-01-2017, 19:03
wywyit's Avatar
wywyit wywyit is offline
AKA: Wyatt Tauber
FRC #3102 (Tech-No-Tigers)
Rookie Year: 2014
wywyit is an unknown quantity at this point
OM5P-AN and OM5P-AC Config Problems
We have our new OM5P-AC radio that we are trying to configure for the 2017 season. However, once I load firmware and configure it using the FRC Radio Config Utility (version 17.2), I am able to communicate with the radio, but not the roboRIO. I have followed WPI's instructions and am adhering to R63 (connect roboRIO to 18-24v POE). I have all network adapters except my PC's Ethernet port disabled when configuring the router.
The router appears to flash firmware and configure fine, and I can see and connect to the wireless network with our driver station. However, after I connect to the wireless network I cannot communicate with the roboRIO. The light for "Robot Radio" lights up in the diagnostics section of the driver station, but the roboRIO never makes connection. However, when connected through USB to the roboRIO, I can communicate with it, deploy LabVIEW code, and "drive" the control system, so I believe I have the roboRIO set up properly.
I tried the same process on an OM5P-AN that I know worked last season, and got the same result. Any suggestions?
