Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2017, 00:24
MRT45's Avatar
MRT45 MRT45 is offline
FRC #0253 (Mills Robotics Team)
Rookie Year: 2013
MRT45 is an unknown quantity at this point
Ribbon Wire for MSP 430 launchpad (Texas Instruments)
Hey everyone,
So apparently I ordered ribbon wire fromm digikey and the excepted time of arrival will be 3/15/17....
https://www.digikey.com/product-deta...036M-ND/999158
Yea, it doesn't help and I need the wire ASAP....
Anyway, does anyone have any suggestions of alternatives for this wire linked above?
Thanks.
Unread 18-01-2017, 08:14
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Re: Ribbon Wire for MSP 430 launchpad (Texas Instruments)
Amazon has a bunch of them on Prime. I used the search term "ribbon wire 20p".
Pc Accessories - Connectors Pro 100 Feet Spool 1.27mm 20P IDC Flat Ribbon Cable for 2.54 mm Connectors, 20 Wires, 20C https://www.amazon.com/dp/B00RX55SZW..._-N2FybRD9E5KE
Unread 18-01-2017, 08:36
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
Rookie Year: 2013
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
That item is just the cable, and doesn't have the connectors on the ends.
The Digikey items are what they call "Value Add," which means they assemble the cables in-house and send them to you, which increases lead time. You can do the same thing, but personally I never have much success with manually crimping those ICD ends on. Something like this will work fine as a replacement for your Digikey part, just make sure it's the right length for you: https://www.amazon.com/Pc-Accessorie...bbon+cable+20p
