Go to Post ...the future of FIRST is very bright with all the great students and mentors coming out of the program, staying involved, and contributing their ideas and energy. - Jason Morrella [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 18-01-2017, 07:37
AtomicBrawlers's Avatar
AtomicBrawlers AtomicBrawlers is offline
FRC #5401
AtomicBrawlers is an unknown quantity at this point
Trying to count EVERY cycle of a photoelectric sensor in your program
My team wants to use a photoelectric sensor or photoswitch to measure and manage the rpm of a flywheel shooter. So there'd be something such as retro-reflective tape on the wheel that would trigger the sensor every rotation. The issue we don't see anyone else talking about is how to get 6,000+ readings per programming cycle. By this, I mean the ~20ms it takes for an FRC Robot to run through it's commands.
For example, if the wheels are rotating ~6,000 rpm, that means 100 rotations a second that must be counted. If a robot can only retrieve data every ~20ms (it's not consistently 20ms) , that means there's ~2 rotations every second.
However, the wheels are not at a constant 6,000 rpm and the data isn't processed at a constant 20ms, so how do you get around the issue of the wheels rotating too fast for the code to read?
One option is a hardware counter, something the photoelectric sensor connects to that keeps track of how many times it's triggered and then sends that number when the code asks for it every ~20ms. If this is your solution, do you have the name of the part you used to do this?
Does anyone know of any teams that have done this who's code is available to read?
Unread 18-01-2017, 08:16
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Trying to count EVERY cycle of a photoelectric sensor in your program
What you'll actually need to do is configure a counter or encoder to the digital input that the sensor is plugged into. This will take care of all of the counting through the FGPA and you just read it like it is a normal encoder.
You can see an example of how we did it here.
Unread 18-01-2017, 09:21
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
If you're using Talon SRXs, they can also read encoders at high speed - plus connecting encoders directly to the SRXs allows you to do cool things like onboard high rate PIDF control. You can read the encoder from the SRX using CANTalon.getPosition()
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 18-01-2017, 09:41
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The FPGA in the roboRIO runs at 40MHz (25ns/sample)
Use an input configured as an FPGA counter.
