Go to Post Be realistic in your goals, and relentless in hitting them. - IKE [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 18-01-2017, 10:58
ankiewiczk ankiewiczk is offline
FRC #1761
ankiewiczk is an unknown quantity at this point
Can you split Encoder signal to two talon srx's for PID Control
This year is our first year we are using CANtalon srx motor controllers. We would love to use these to do velocity control pid directly on the Talons for our DriveTrain (not go through the roborio because of speed).
The problem is our drivetrain is two motors to one gearbox with one encoder ( this seems to be the default for dafault KOP setup). Is there a way to safely split the encoder signal to two talon srx's for PID control? Or is there a way, to have the encoder signal shared on the CAN bus?
Any other common solutions to this problem ?
Unread 18-01-2017, 11:01
Billfred's Avatar
Billfred Billfred is offline
Re: Can you split Encoder signal to two talon srx's for PID Control
Take a look at Follower Mode, and just hook the encoder up to one of the Talons: https://www.ctr-electronics.com/Talo...e%20Manual.pdf
Sent from my desk at AndyMark
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 18-01-2017, 14:14
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
To add on to what Billfred said, check out Section 7.6 of the manual he linked.
It has specific steps and recommendations for when you have multiple Talon SRXs and a single sensor.
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
