Go to Post I know FIRST is all about changing society. But my approach is one person at a time. - Phil 33 [more]
Unread 18-01-2017, 17:07
gmalexander29 gmalexander29 is offline
FRC #5000
gmalexander29 is an unknown quantity at this point
Can't import CANTalon
When I type in import edu.wpi.first.wpilibj. I don't see an option for CANTalon
I have updated to the latest WPILib
Unread 18-01-2017, 17:08
FRC #5000
Re: Can't import CANTalon
Forgot to mention I'm using a Mac
markmcgary's Avatar
markmcgary markmcgary is online now
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Read this: http://wpilib.screenstepslive.com/s/...arty-libraries
Unread 19-01-2017, 16:39
FRC #5000
I downloaded and copied the java folder to wpilib/user/java/lib and I still can't import com.ctre without getting an error
Unread 19-01-2017, 17:02
jbc218 jbc218 is offline
FRC #4910 (East Cobb Robotics)
Rookie Year: 2013
jbc218 is an unknown quantity at this point
Have you added the library to your build path in Eclipse? If not, you can do this by right clicking the project name in the project explorer, go to build path -> configure build path -> libraries tab -> add external jars, and then just select the .jar.
Unread 19-01-2017, 19:24
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
You do not need to manually add external libraries to your build path.
When you start Eclipse, the WPI Plug-ins automatically add anything in the appropriate WPI/user folder to the build path.
This means that anytime you add an external library, you must restart eclipse.
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
