Go to Post What if my teams drive train isn't an option? - MARS_James [more]
Unread 19-01-2017, 08:33
jcmythree jcmythree is offline
FRC #3366
jcmythree is an unknown quantity at this point
Problems with CAN and Roborio Web system configuration
We do not show a CAN interface on the web based system configuration for Roborio Any suggestions as to what may be causing this problem would be appreciated.
Unread 19-01-2017, 10:01
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: Problems with CAN and Roborio Web system configuration
We need a little bit more information. What do you have on your CAN network? Are these devices showing a CAN fault (see the documentation for each device to see what this looks like)? Is the CAN network properly terminated at the PDP or with a 20 Ohm resistor? Any other extraneous info might also be helpful in diagnosing your problem.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
